New Smooth Lock Covers
Old Sep 26, 2009 | 03:24 PM
hyperv6's Avatar
Here is something I found on a Camaro I judged at a Camaro show. The guy who owned the new Camaro sells them. It is called a Smooth Lock. It is a piece similar to the door handel that stick on you key lock that you never use if you have a remote entry.
It is small but cleans up the door handel look. I like small details that look stock but clean up the look of the factory piece. He does not show them on his web site for an HHR since mine was the first one he tried to fit.
I though some here might like this for a cheap and easy upgrade. Also you only need one for the HHR.
He sells them direct so you need to contact him direct.
http://www.smoothlock.com/
If you need the lock you can jut pull it off if needed.
Old Sep 26, 2009 | 04:38 PM
Stryker's Avatar
Might actually be enough to thwart someone who got your key but didn't have your fob. "OMG this car has no locks....dude...."
Old Sep 27, 2009 | 10:22 AM
xzombiex66's Avatar
Awesome i really like these. i have seen some in the past the were flush with the handle, but didn't look right. Nice find!!!
Old Sep 27, 2009 | 11:31 PM
a76marine's Avatar
That's pretty tight... do you know what size we need if we wanted to order one?
Old Sep 28, 2009 | 05:27 AM
Jeff®'s Avatar
Looks like you painted a dime black and glued it in there.
Old Sep 28, 2009 | 05:32 AM
hyperv6's Avatar
You will have to contact the guy as he has no size posted for the HHR since this was the first try.
Old Sep 28, 2009 | 05:35 AM
hyperv6's Avatar
You see FDR anywhere?
If you have anything but black I think you need to paint them. That shoulld not be an issue. Spray or Brush should work fine since it is so small.
cooltravlin
Tires & Wheels
Sep 4, 2020 03:42 PM
Black Rose
Jul 17, 2010 12:38 PM
Father Azmodius
32
Nov 25, 2009 12:06 PM
dnewmanut
Apr 25, 2007 02:08 PM
galladanb
0
May 4, 2006 05:10 PM
