Oil life indicator reset
Or you can turn the key to the on position and press both the info and reset button at the same time for a few seconds and then scroll through the menu till you hit the oil life reset and just hold the reset button until it says reset/acknowledged.
The manual for my 2010 says to do do as described above with the info button but for some reason, it did not work. I read it again and it said with the 2.2 engine, you can also depress the gas pedal 3 times within 5 seconds after turning the ignition on and that did it.
