p0014 code
Old Oct 27, 2023 | 12:00 AM
lmhere329's Avatar
p0014 code
how many miles do i have to drive the car 2010 chevy hhr to reset computer after replaceing the sencirs to keep check light out
Old Oct 27, 2023 | 05:58 AM
to the forums!
For code P0014, you should replace the exhaust VVT solenoid valve and also remove the valve cover to check the timing chain. It must be tight, any looseness means that you need to replace the timing components.
Old Oct 27, 2023 | 06:46 AM
Welcome to the site, you could disconnect the negative battery terminal in the rear spare tire area. Just 15 seconds should do it.
Old Oct 27, 2023 | 07:02 AM
Welcome
For a code P0014 if you replaced some “sensor”, then you probably replaced the wrong part. You need to replace the exhaust solenoid as RJ RS SS 350 stated above.
Old Oct 27, 2023 | 09:26 AM
greg8453's Avatar
What exactly has been done to the engine?
Old Oct 27, 2023 | 08:15 PM
PulpFriction's Avatar
Could you post a pic of the parts you replaced?
gag
Apr 12, 2024 07:13 AM
hefleymusic23
Aug 1, 2023 11:15 PM
06REDSEDANDELIVERY
Apr 24, 2023 04:51 PM
shojay92
Dec 4, 2021 03:02 PM
ecpff
Aug 21, 2016 04:13 AM
