Paint Code? How do I find it?
Old May 2, 2008 | 11:33 PM
  #31
mudd274's Avatar
I got one of the pens at the dealer today for 10.??. It has a brush and a pen on it. My color is the SOM. See the dealer and they will find the code. The 10.00 cost was cheap enough.
Old May 3, 2008 | 11:48 PM
  #32
ЯX-8's Avatar
I will need more than a pen, I'm looking to painting my Mazda RX-8 that color. Any case, I already tried emailing Chevrolet about it, but they couldn't help me out. I will just go to dealership, and ask someone there..
Old Sep 7, 2008 | 03:42 PM
  #33
bigdog9586's Avatar
My 08 HHR has the sticker in the glovebox but at the bottom of the sticker where it says WATERBASED there is no numbers after it but clear to the right on the same line is 192, this can't be it so is there another way of finding the code?
Old Sep 15, 2008 | 01:33 PM
  #34
marksand's Avatar
This has been an interesting quest! When I purchased my 2008 HHR, I was told it was "Dark Gray Metallic." However, all the paint references call it "Techo Gray Metallic." Further, the paint code in my glove box is, waterbased 19B. However, reference charts show it as WA411P / 75
Very confusing for a dyslexic! LOL!
I would think Dark Gray would be the Techno Gray. The paint code can be found inside the glove box.
Old Sep 15, 2008 | 01:51 PM
  #35
ZTony8's Avatar
The paint code is in 2 places on the I.D label.In the lower right corner,it's the
WA number.In the lines of numbers it's a number near the end of the string(in your case,75) followed by either a "U" or an "L".
Old Sep 15, 2008 | 02:18 PM
  #36
marksand's Avatar
Tony,
THANKS! 75U is it.
Mark
Old Jan 19, 2009 | 03:54 PM
  #37
masterchief1112's Avatar
all my box says is water based 147, i have an imperial blue metallic. i have an 07. just thought this was weird.
Old Jan 19, 2009 | 04:22 PM
  #38
ChevyMgr's Avatar
Look for the RPO code with the U as ZTony8 said. A bit of trivia. The reason for the U was back in the day we had Upper and Lower paints. When two tone went away the U stayed around.
Or check the sticky in the General forum for all RPO codes, which is where I copied and pasted this from.
17U Primary Color - Exterior, Switchblade Silver Met (09)
37U Primary Color - Exterior, Imperial Blue (07)
38U Primary Color - Mystique Blue Flash Met (08)
41U Primary Color - Exterior, Black (02)
50U Primary Color - Exterior, Olympic White (02)
51U Primary Color - Exterior, Gold Mist Met (06)
61U Primary Color - Exterior, Aqua Bluer Met (09)
71U Primary Color - Exterior, Lunar Quartz Met (06)
74U Primary Color - Exterior, Victory Red (02)
75U Primary Color - Exterior, Techno Gray (07)
79U Primary Color - Exterior, Merlot Jewel Met (08)
89U Primary Color - Exterior, Crystal Claret Tintcoat (08)
Old Jan 19, 2009 | 04:52 PM
  #39
turbotim's Avatar
Do you know if the dealership will sell any touch-up paint for the interior? I put a little chip in my arm rest with my briefcase. I tried the parts store mix it yourself patch stuff and cannot get the color right. I would like to go over the chip with the factory color so it is not noticeable.
Old Feb 5, 2009 | 04:03 PM
  #40
Lil Cheney's Avatar
I pulled off an U817K. Is this right? Thx
