Passenger CV axle problems
07 2.4 auto trans.
Took out driver side CV axle with no problem, how ever the stub on passenger side, did not come out with the half shaft.
So now I'm stuck, researching on how to remove it from the transmission.
Tips or links while I'm searching are aprecaiate.
I stupidly didnt research before tackling this task....
so I did too, since the stub stayed inside transmission I just swapped to a new CV axle.. but now the passenger side CV axle does not spin when in gear
Am I thinking this totally wrong, or am I correct in thinking that only one axle will turn (in this case the drivers side) while it is in the air? It isn't posi-traction or a locked diff.
