Playing with Torque OBDII reader
Old Aug 19, 2013 | 10:45 AM
2011 LT, no super charger. Torque has a "boost" display, so I set it to look see. at idle it is showing -9.2 psi, when I rev it a bit it goes to -11.0 psi.
What do you suppose it is really measuring? Doesn't seem to be manifold pressure that is different numbers.
Old Aug 19, 2013 | 11:50 AM
Vacuum somewhere ?
Old Aug 19, 2013 | 09:36 PM
IgottaWoody's Avatar
Vacuum...under a load that number will go to zero, atmospheric pressure...under lite/no load the vacumm created exceeds the A/P and will show larger neg numbers..good tuning tool once you understand how it works...the results of the pistons pulling in air on the down stroke...reading taken from MAP sensor...
Old Aug 20, 2013 | 02:31 PM
OK, I drove it and you are right , it seeks to zero. So that would actually be manifold vacuum, versus the other manifold pressure PID?
Old Aug 20, 2013 | 04:03 PM
prod's Avatar
Same reading from the MAP sensor I would think. Choosing the turbo/vacuum option just creates a display with positive values for when its in boost.
Old Aug 21, 2013 | 10:35 AM
right..same as a vacuum gage..only it also goes positive press
Old Aug 21, 2013 | 02:05 PM
I'll bet that 's why some SSs need the electrical vacuum pump for early use of brakes then.
Old Aug 21, 2013 | 08:42 PM
That would be correct...cold start up has the turbo applying low pressure (about -10 on boost gage).. so vacuum is limited for build up until the idle settles down, then is shows around -20,..for some odd reason ,the brake booster loses its charge aftera few hours...
cannuck
2.0L Performance Tech
Sep 25, 2013 09:35 AM
BigT
Maintenance and Upkeep
Nov 10, 2012 06:10 PM
db/sb
Dec 15, 2011 10:41 AM
