Please help with some noises
Old Dec 5, 2008 | 01:22 PM
meriquillo's Avatar
Thumbs down Please help with some noises
Hi guys i need some help with this, i took the car to the dealership because i suspect i have the steering column/shaft issue and since i bought the car used i also purchased the extended warranty. Steering problem will be covered by the service contract but i have some other issues that won't be covered and honestly what dealership is telling me does not make any sense.
The other problem is when i'm making a turn there is a roaring noise coming from the wheels i think, is like i had my wheels flat. the lower the speed the louder it is (like when parking or driving in parking lots)sounds like i was driving a pick up truck with mud terrain tires. dealership says they need to add knuckle splash shield or hub splash shield? they said my 2006 didn't come with those shields and that's what makes the noise? grime ,dirt,etcgettin in the hub i think? . The other noise is a rattle noise coming from the right front strut (i think is the strut mount) it does it when cold for first 5 minutes of driving and goes away. dealer wants to change struts even when they they're fine but have some new revised parts. What do you guys think?? any problems like this with your cars?
Thank
Old Dec 5, 2008 | 01:32 PM
ChevyMgr's Avatar
Roaring noise is a hub bearing most likely. Other possiblity would be tire noise but hub bearing is the usual culprit. Too many possibilities on the other noises to give an over the internet diagnostic guess.
Old Dec 5, 2008 | 02:06 PM
meriquillo's Avatar
thanks for your response, so hub bearing even when is just when making turns? does not make noise going straight.
Thanks
Old Dec 5, 2008 | 02:25 PM
ChevyMgr's Avatar
Thanks
Since there is more pressure on the bearing on turns I would say yes, but a tech test driving will know better than me.
Old Dec 5, 2008 | 02:28 PM
esmarkey's Avatar
This is one of those cases where you may be glad you bought the extended warranty!
Old Dec 6, 2008 | 12:18 PM
meriquillo's Avatar
yes i always get the extended service for used because you never know. i'll let the dealership deal with the steering column and i'll get a second opinion for the suspension thing since is not covered.
i'll keep you all posted
Old Dec 6, 2008 | 12:25 PM
ChevyMgr's Avatar
How many miles on your vehicle? What is their diagnosis on the suspension noise and roaring noise?
Old Dec 6, 2008 | 07:04 PM
meriquillo's Avatar
dealership says they need to add knuckle splash shield or hub splash shield? they said these cars didn't come with those shields and that's what makes the noise? grime ,dirt,etcgettin in the hub i think?funny is that i asked them if the hub bearing was bad then and they said no. so waht in the heck is making that noise? . The other noise is a rattle noise coming from the right front strut (i think is the strut mount) it does it when cold for first 5 minutes of driving and goes away. dealer wants to change struts even when they're fine they say but have some new revised parts. Honestly i think they want me to pay $1100 in repairs not covered by warranty and deal with my noise anyways.
IntegrityHI
14
Dec 11, 2012 06:20 PM
thegodfather
Oct 18, 2011 10:00 AM
TiggersHHR
Mar 14, 2011 12:22 PM
Woodyi77
Mar 11, 2009 10:29 PM
Programmer
Jun 15, 2008 02:53 AM
