Possible to increase Remote Start run time beyond 10 minutes?
Old Feb 12, 2008 | 11:33 AM
Originally Posted by LeEarl
How about when you want the inside of the HHR to warm up enough so when you get in you dont brake anything When it is -30˚+ it is nice to get into a warm vehicle and 10 min just dont make it....
You can do this twice at 10 min. So in 20 min. everything should be nice and warm.
Old Feb 12, 2008 | 03:24 PM
Black Rose's Avatar
My father in law puts a small electric heater inside their van (on a timer) when he knows that it will be brutally cold overnight and sets it to come on about half an hour before the MIL needs to drive it.
Old Feb 12, 2008 | 03:37 PM
tim_tenn's Avatar
10 minutes the first start. You can press the remote start a second time while the vehicle is running (provided you have not unlocked the vehicle). This resets the timer to 10 minutes. So if you press it again after it's been running for 3 minutes, you don't go to 13 minutes, you go back to 10. There is a limit of 2 starts from the remote -- after that, there must be a key inserted in the ignition and turned to on before the remote start will work again.
Old Feb 12, 2008 | 04:08 PM
Lone Ranger's Avatar
I did not know this. Guess I need to read the manual, lol.
Old Feb 12, 2008 | 04:49 PM
Old Ray's Avatar
My 07 Premier was supposed to have remote start. I know that you will find this hard to believe but my salesman after a two month wait arranged for a dealer transfer of the wrong car, No remote start, much distress all-around, negotiated a extra discount and took it. Don’t miss the remote start that much but I didn’t know that it only runs the car for 10 minutes (or 20 with restart), not so good for the great frozen north, next to useless actually.
Sooooooooooo one more reason for getting the SS with the 5 speed, if anymore where needed.
Old Feb 12, 2008 | 05:13 PM
ChritonHHR's Avatar
My only problem is to remember not to turn off the heat off when I get out
Old Feb 12, 2008 | 07:35 PM
SLOWHITE's Avatar
You can't set it for longer than 10 min, but if you repeat the procedure during the initial 10 min period, it will run for 10 more minutes from the time you repeated the procedure. Or of course you could just start it again, but like mentioned earlier, can only remote start the car twice, then have to use a key.
Old Feb 12, 2008 | 07:54 PM
DreamHHR's Avatar
http://www.canadiandriver.com/articles/jk/071219.htm
Old Feb 13, 2008 | 12:14 AM
Snoopy's Avatar
Man, that is a really interesting article.
It kind of parallels one in regard to California drivers (they being the highest populated state). The article said if they could get California drivers to just do the speed limit, PLUS 5 OVER, the consumers would collectively save several hundred milllion dollars annually.
Note....the article didn't indicate what would happen IF the money was saved.
Old Feb 13, 2008 | 04:12 AM
quest51210's Avatar
they save $9 per car, per year in Canada...
