Power door lock help.
Old Feb 23, 2010 | 12:23 PM
ChevyMgr's Avatar
Originally Posted by redbaron
The vin is 3GNDA23D88S55018.
Still not correct. There are only 16 digits and a VIN has 17.
All I need is the last EIGHT. Not the full VIN. All I want is 8SXXXXXX. There will be 6 numbers after the 8S. The VIN shown only has 5 numbers after the 8S
Old Feb 23, 2010 | 05:46 PM
skyeglen's Avatar
Yes, you can get FOB,s from the dealer or a number of other places. You also might ask how much to reprogram the FOB's to the BCM so they will work. Prices vary greatly from $0 to $125 depending on the dealership.
PN for FOB with remote start (mine is an '06, don't know if they are all alike) is 15114374. You can also get a FOB with just the lock/unlock features.
Old Feb 23, 2010 | 06:57 PM
Yes, but go back to the "was it a rental" question. If it was, there is a good possibility you will go thru the gates of hell to make it work, and possibly have to pay more than once. An alternative I found was an after market remote door lock system, I got at PEP BOYS, I've seen them elsewhere, for about $60, the problem with it is that you still cannot relearn TPMS positions.
The wiring for these is somwhat of a challenge, but pretty do able after you figure out the correct color codes from conflicting/incorrect/hidden information.
Old Feb 24, 2010 | 11:36 AM
redbaron's Avatar
MMM??? I will check again Chevy Mgr. Tks.
Old Feb 24, 2010 | 12:48 PM
redbaron's Avatar
ChevyMgr.
Ok, try this! 8S last 6 are 550518.
Old Feb 24, 2010 | 01:00 PM
ChevyMgr's Avatar
ChevyMgr.
Now that worked. You have keyless entry with remote start. So now all you need to do is buy a key fob, get it programmed and life will be good.
This was a Hertz rental vehicle originally.
You also have the storage compartment recall still open. This will be fixed for free.
Old Feb 25, 2010 | 07:49 PM
redbaron's Avatar
Chevy Mrg,
Many thanks! I am in the process of having that done as soon as the FOB arrives.
GREAT FORUM!
Bill
Old Oct 13, 2011 | 03:21 AM
Blue Rookie HHR's Avatar
RE: "PN for FOB with remote start (mine is an '06, don't know if they are all alike) is 15114374. You can also get a FOB with just the lock/unlock features."
Really? A 3 button FOB with just the lock/unlock features will also work if my originals are 4 buttons? Does it matter that the part numbers stamped on them are different than the ones with "remote start"?
Old Oct 14, 2011 | 07:51 AM
key fob #
if you have the remote start option, the key fob # is 15114374. I would check with the seller and confirm iif they forgot to give yuou the fob's only a dealer can prograam the fob to your HHR there is no sequence to set it yourself
jbbadboy
Jan 12, 2016 12:11 PM
p.b.hart
Apr 5, 2015 01:45 PM
JohnFS
Aug 19, 2014 08:49 PM
jerry4155
Mar 12, 2013 10:22 AM
hhrss09
Sep 13, 2009 06:58 PM
