Power steering motor?
Het gang,
My '06 2LT, 190k, started having today an issue. While turning the steering wheel, I feel a small but very active/fast vibration in the steering wheel. This also happens if I turn the wheel at a stop. By turn, I mean maybe 5 degrees at the steering wheel. Could this be a warning that my steering motor is about to die? I've read about the failures, but not of any early warning signs. |
Either the motor or the intermediate steering shaft
Has the motor been replaced before the extended warranty started?
Original motor as far as I know.
Bought the car in Dec 2016. |
Then it was recalled/warranteed.
had my steering motor die on me this summer and GM replaced it NO CHARGE with 180,000 miles.
Originally Posted by jimvw
(Post 930559)
Mine hasn't died, YET.
I just started feeling, and now hearing, something as I start to move the steering wheel. I'm just wondering IF the motor is starting to go bad. Do I have to wait for motor failure to contact GM? Thanks always for the input and help |
Yes, they will be checking for the EPS motor failure, have you inspected the I S S
2006 was a recall. No that is not a symptom of failure. Failure comes from overheating then the thermal fuse blows then resets after it cools down.
