Press for bushings
Old Mar 3, 2019 | 06:16 PM
chevyenvy's Avatar
Press for bushings
My 2007 HHR has wear in it's control arm bushing and rather than pay for a arm(I replaced the control arm both drivers and passenger 4 yrs ago) what about just replacing the bushings ? Can you use a "rental press" from Auto Zone or O'reily?
Old Mar 3, 2019 | 08:34 PM
Yes, or a hammer and socket.
Old Mar 3, 2019 | 09:04 PM
Ohiocruiser's Avatar
Auto zone "rental press" didn't work for me. Ended up going to local shop and paying $100 to press them in.
Old Mar 3, 2019 | 09:23 PM
You need to get 2 kits. it is a threaded rod and fittings. IIRC, a ball joint kit and a control arm kit.
The Official tool is J-41211
Old Mar 4, 2019 | 07:52 AM
Ed ke6bnl's Avatar
I used a press but had to make something to push on the bushing that fit the hole and pushed on the outer ring
Old Mar 4, 2019 | 07:54 AM
I used a rental ball joint press!
Old Mar 4, 2019 | 08:56 AM
Cat Man HHR's Avatar
This video shows how to check rear bushing
This video is of a Honda but it's the same procedure for the HHR for the rear bushing as far as removing and installing.
Old Mar 4, 2019 | 09:00 AM
Old Mar 4, 2019 | 10:48 PM
Krunk's Avatar
I got new arms. I figured after the amount of time to press out/in bushings, and then grind off rivet heads to get the ball joint off; my time was worth the extra cost.
Old Mar 5, 2019 | 09:48 AM
But to get the ball type Moog bearings, you have to press those, the arms only come with rubber bushings.
