Reactivating DRL?
Old Jan 16, 2014 | 08:29 AM
SwissHHR's Avatar
Reactivating DRL?
Hello all,
I have looked through the various forum articles regarding DRL, but haven’t found an answer to my question yet. I have read that most HHRs seem to be equipped with some sort of DRL. However, mine (retrofitted for Germany/Switzerland) doesn’t have any DRL whatsoever, even when on Auto-On lights setting.
I would like to activate the “Canadian style” DRL, meaning that the low beam lights are always on with reduced intensity. Fuse 31 is there. Is there anything else I should check or change (if it’s possible at all to reactivate it...).
Regards,
Patrick
Old Jan 16, 2014 | 09:00 AM
Lucky's Avatar
I know that the DRL's are controlled by the body controller. I would guess that the controller is programed differently for your country.
Old Jan 16, 2014 | 10:19 AM
run thru the DIC and see if you can reset them there.
Old Jan 16, 2014 | 12:04 PM
skyline26's Avatar
I think Lucky is right...try and see if you can find a used or new one from Canada and ship it over
Old Jan 16, 2014 | 02:29 PM
Snoopy's Avatar
Yeah, right Skyline.....
He should go through the expense of buying a new/different vehicle and then the expense of packing and shipping it to Europe, then pay the duty fee......all for wanting DRL's. I really like your thinking. (having fun, don't get upset).
Old Jan 16, 2014 | 03:40 PM
Putter's Avatar
Not sure if ALL HHRs are like this, but mine (2009) has a relay & seperate fuse in the under-hood panel to control DRLs. I purposely pulled the fuse to keep mine from coming on.
Might be that simple.
Old Jan 16, 2014 | 08:08 PM
I thought there was a relay also.
If it's a 2006 DRL will be the marker/turn signal lamps.
Skyline was talking about importing the Module, not the car.
Old Jan 16, 2014 | 08:37 PM
skyline26's Avatar
haha Snoopy...i dont mean him buying the car..i meant module!
Old Jan 17, 2014 | 05:00 AM
SwissHHR's Avatar
Thank you all for your input. The DIC doesn't seem to have any relevant settings. I will go over the manual and check for the relay you mentioned.
Old Jan 21, 2014 | 02:39 AM
SwissHHR's Avatar
Ok, checked and DRL fuse and relay are there. Seems then that the DRL behaviour is controlled by the software I guess.
Could the body controller be programmed by a GM car dealer?
