Rear hatch opening
Old Nov 26, 2019 | 04:24 PM
Jit's Avatar
Jit
Rear hatch opening
Hello
i have a SS and the battery is dead.
Is there a rear hatch emergency option to open from inside the car?
Thanks
Happy Thanksgiving!!
Old Nov 26, 2019 | 04:34 PM
Look in your Owner Manual?
Old Nov 26, 2019 | 04:49 PM
Yes there is. As Don said, look in your owners manual. It has all the fine detail points on how to use it.
After you get familiar with the emergency release you really don't need to use it. Just hook up your battery charger or jumper cables under the hood. You'll then have battery power () to "pop" the hatch.
(sorry Don. Had to let him in on the Top Secret info...... )
Old Nov 26, 2019 | 05:41 PM
Jit's Avatar
Jit
Thanks...especially since I Dont have an owners manual!!
Old Nov 26, 2019 | 05:50 PM
Yes you do. We have them on this site for download............FREE !
Not sure how many times Donbrew has mentioned this over the years AND that he has a LINK to them posted right there in his sig.
Old Nov 26, 2019 | 05:59 PM
We are hiding them real good! Not highlighted or all caps or underlined or anything, just tiny small print hidden away.
Old Nov 26, 2019 | 06:45 PM
If you have a 9 bolt battery and power port adapter, you can plug in the adapter and connect the battery then go out back and pop the hatch.
Old Jul 16, 2020 | 04:38 PM
MedicFL1's Avatar
Hello
Thanks
Inside the car on the rear hatch panel there is a removable plastic piece - remove it using a screwdriver
Now stick that screwdriver in the hole at the bottom edge of the panel rail - pushing straight in - will take multiple tries until door pops open.
This happens with a dead or low battery situation.
Disconnect the Negative Battery cable First
After ~30 minuets replace with a New Battery and replace plastic tab back on the inside of the door panel.
The manual makes this sound easy but we had to make a few attempts to get it open, but it worked.
My battery was at 12.48 when the FOB would not open doors and Alarm would not shut off.
Old Jul 16, 2020 | 04:53 PM
My battery was at 12.48 "when the FOB would not open doors and Alarm would not shut off."
Then why not unlock the door with the key ? Then turn on the ignition to kill the alarm.
We were just trying to explain to Jit that he didn't need to use the emergency hatch release. There are much easier ways to open the hatch.
(Oh. And this thread was from last year)
Old Jul 17, 2020 | 07:44 AM
I unlocked the driver’s side front door with the ignition/door key, the alarm didn’t stop, I inserted the ignition key into the ignition switch, and turned the key to the start position and released, the alarm didn’t stop, the 12.3 volts was to low the allow the BCM to recognize the signals. The AAA guy inserted the 9 volt device into the power port, the alarm shut off and the rear hatch touch pad worked to open the rear hatch liftgate. The battery, just 4 years old, had 2 dead cells and was pronounced dead, a new battery cured the issue.
Before he installed that new battery he , ensured the ground wire connections were clean and tight. That battery lasted 7 years.
