Reg vs Super
Old Jun 6, 2007 | 08:45 PM
Dave C's Avatar
I only put 93 in any vehicle so it didn't make a difference to me that the 2.4 is supposed to use premium. Even if Chevy said 2.4 required 87 I would still put in 93.
It's your money, but buying excess octane is just wasting money
Old Jun 6, 2007 | 09:01 PM
captain howdy's Avatar
Screw money, only the best for me. My last two vehicles and HHR could use the extra octane. My last car was a modded 02 V6 Mustang that had the computer programmed to run on 93 and if I remember correctly GM recommended premium for my 99 Sunfire GT just like my HHR. On my 89 Grand Am I was probably wasting money but it was a high mileage vehicle and I never had any pinging or anything so maybe it wasn't a waste.
Old Jun 6, 2007 | 10:10 PM
chingchonger's Avatar
Octane rating does not make the fuel quality better or worse. Higher octane fuel does not burn as easily, that's what helps prevent engines from knocking/pinging/detonation.
If your engine is not knocking and you are putting in anything over regular, you are just burning money.
Put in whatever the manufacture recommends until the end of your warranty. After that, do whatever you want.
When a vehicle equipped with a knock sensor starts knocking, it automatically retards the timing to compensate. Over time, this compensation will decrease the fuel economy.
Knocking usually occurs ONLY during wide open throttle. If you are flooring your gas all the time, you're going to get lower fuel economy regardless of knocking.
Old Jun 6, 2007 | 10:16 PM
Snoopy's Avatar
Originally Posted by JoeR
Food for thought:
No matter what the octane (which only effects flame propogation rate) rating of the gas, the actual BTU content (energy available) is the same!!
The 2.4 ECM is programmed with two spark timing tables. The engine also has a knock sensor. If knock is detected from say lower octane fuel, the ECM is also programmed to "average down" between the two tables to an ideal advance setting so that knock does not take place.
Whether using low or high octane fuel, the timing self adjusts to optimize for the fuel used.
Bottom line.... It won't and cannot make a difference in fuel mileage. The ability of the ECM to operate in the higher spark advance range with higher octane fuel will result in "slightly" more power, but nothing earth shaking.
Joe....if I remember correctly, you are absolutely correct about this. But need to make one addition.....
the programmed parameters in the spark timing tables will not adjust to "sub grade" gasoline....like 85 or 86.
Otherwise, as usual, right on the money.
Old Jun 6, 2007 | 10:34 PM
Do they even sell 85 or 86 at gas stations? I don't think I've ever seen it at a pump.
Old Jun 7, 2007 | 12:28 AM
Snoopy's Avatar
I ran into 86 someplace last year on a trek across the US. Want to say Texas panhandle, Kansas, Oklahoma, Missouri. Not sure which one.
Of course, a number of years ago, there was a scandle about a very small chain of independent stations that was using sub grades and lableing it 87. I think the name was something like Brennan.
I guess it depends on the area of the country.....or Mexico.
Old Jun 7, 2007 | 06:12 AM
Black Beauty's Avatar
That`s absolutely correct, the only time the engine will knock is under hard acceleration, or heavy load, like pulling a trailer or steep incline.
Other than that, it should not happen, and you certainly can`t expect to get great mileage under those conditions...
Old Jun 7, 2007 | 07:35 AM
Goose's Avatar
I haven't seen it lately buy I remember seeing 86 at Sunoco stations
Goose
Old Jun 7, 2007 | 07:43 AM
JoeR's Avatar
Right, Snoopy, but... Those "programmed parameters" are programmable! Tuning is fun!
Never seen anything like 85 or 86, but actually the low octane table could be adjusted downward and the car would run fine on it without knock, albeit with a power loss.
Old Jun 7, 2007 | 07:49 AM
JoeR's Avatar
Screw money, only the best for me. .... (clipped)
OK, Howdy, you set yourself up on this one!!
(highjack in progress)
If "only the best" for you, what kind of beer do you prefer??
