Remote Entry
Old Dec 20, 2011 | 09:22 AM
Haunted_Hot_Rod's Avatar
I remember running the check and it said no rental/fleet.
It is an automatic and I'll check the Code at lunch.
should the RKE open the cargo doors also?
Old Dec 20, 2011 | 09:24 AM
foolmoon_design's Avatar
Now that you have the fobs on the way it should only be about 90 bucks to flash them. They usually can do this right at the service counter in under a minute or two.(at least at my dealer).
I may have read this wrong, but why re-key the car, just have a 2nd key made for a few bucks, hell of alot quicker and cheaper
Old Dec 20, 2011 | 09:27 AM
Not re-keying. Having 2 spares made. And programming them.
Fobs are the only thing I am not sure on now. With buttons for the cargo doors or without?
Just now realizing how busy I have been.... 6 months to get around to this.
Old Dec 20, 2011 | 09:32 AM
db/sb's Avatar
There are no 'cargo door' buttons. Only lock, unlock, panic, and remote start (if so equipped). Do you recall if you ordered fob with remote start or without?
Old Dec 20, 2011 | 09:36 AM
I have not ordered yet.... making sure I order the right one.
Old Dec 20, 2011 | 09:39 AM
db/sb's Avatar
Here's what they look like:
Part numbers are 15114374 (remote start) and 15777636 (w/o remote start).
Old Dec 20, 2011 | 09:58 AM
Keys and remotes ordered.
Thanks for all the help.
2 keys and 2 remotes $63 shipped
Cheers
Doc
Old Dec 21, 2011 | 01:12 AM
prod's Avatar
umm, im pretty sure a 2008 panel has buttons on the remote for popping the rear doors. Maybe pm a panel owner to make sure.
Old Dec 21, 2011 | 02:16 AM
prod- Yes correct, starting for 2008 Panels, we DO have rear remote door popper buttons on the fobs..
So it is a 6 button remote (as pictured), & GM part # is: GM / L:15114376
Old Dec 21, 2011 | 04:36 AM
***SNIP***
That's the remote I was going to order, but was unsure as when I ran the model check on the fob it popped up as not compatible.
Ah well.
I've managed OK for the last 6 months using just the key.... it'll wait until after Christmas.
Cheers
Doc
