Remote start not working in really cold temps
Pretty cold in Detroit area today. IT was 5 below zero this morning when I attempted to remote start my 2007 HHR today. The battery is 4 years old and I believe in good condition. I hit LOCK, got the parking light flash, hit the start button on the fob, got the parking light flash again but it did not start and the parking lights did not stay on as normal. Put on shoes and jacket and it started with the key fine, though cranked a tad slow.
It warmed up at least 10 minutes, drove 15 minutes to work. Turned it off, got out of car and it remote started fine. Tried it from office a couple hours later just to see and it did not start. So I'm thinking it runs some little self diagnostics before start and if it sees something below a certain limit, it wont allow it to start as a self preservation tool. I know for a fact that if the system pops the check engine light, it will not remote start. Any experience, suggestions, ideas?? THanks! |
Welcome to the site, best to ensure the battery and alternator are working and up to proper voltage, my last two batteries were 4 to 5 years old, and 12.2 volts. the HHR and it’s computers like to see 12.4 volts and dry tight ground connections. |
It is hard to fond batteries with more than 48 month warranties. 12v is a 25% charge at 70F; 12.7V is full at 70F
Originally Posted by donbrew
(Post 859786)
Originally Posted by ChazMan
(Post 859797)
Thanks. I took the covers off the battery/apare tire well and run a mini heater in the interior to help keep the battery warm. That helped with my old battery in cold temps years ago, cranking was noticeably better. Hope that helps in this case but it may be just too damn cold.
X2 what they all say - if you are having problems starting it, something is needing attention. Get those tests done.
This happens to me when there is a check engine light on. The car will not remote start until you fix or turn off the check engine light, just the brake light flash. So definitely computer controlled diagnostic of some sort. |
Originally Posted by gio89kid
(Post 859811)
My wife's 2016 Encore has remote start and it did exactly the same thing yesterday afternoon. It was in the garage, about -13 f. I started it with the "key" and it was fine. Let it warm up for a few minutes, shut it off and the remote start worked just fine.
Originally Posted by Lethal Tendencies
(Post 859818)
That is correct. My daughters '09 would not remote start due to the oil change light being on. She had the oil changed and never reset the computer
I may have the charging/battery system checked out, can't hurt and it's free. It will also be 40 degrees this weekend :-) Thanks! |
