replace normal bulb for Halogen
Old Oct 10, 2022 | 02:16 PM
tomasorta's Avatar
Hi Guys, I want to replace the normal bulb from my HHR with Halogen led in headlights.
thanks
Old Oct 10, 2022 | 03:56 PM
Halogen or LED any bulb that a H13 will fit , I have used different brands of both over the years, halogen bulbs only lasted 1 to 2 years. Some LED bulbs a little longer. I have a set of 6 sided LED bulbs in my 2011 , plug and play.
https://www.ebay.ca/itm/174566373795...mis&media=COPY
Old Oct 10, 2022 | 08:18 PM
tomasorta's Avatar
Thanks oldblue. and will be compatible with 2006 also?
Old Oct 10, 2022 | 08:27 PM
The "normal" bulbs are halogen. LED is LED, no noble gas involved.
Old Oct 11, 2022 | 06:20 AM
Yes, our member the_shmoo has led bulbs in his 2006 , no problems
Old Oct 11, 2022 | 02:30 PM
PulpFriction's Avatar
thanks
Depends what you want to accomplish. Do you want brighter lights? First, make sure that the lenses are bright and clear. If they’re hazy and yellow, you won’t see well no matter what bulb you use.
First, the standard bulbs are halogen and pretty good provided the lenses are clear. LEDS are hit-or-miss can of worms, many different designs, even if they’re brighter they may mess up the aim of the beam.
Old Oct 11, 2022 | 04:54 PM
Lonwane's Avatar
Every bulb in my '06 is LED with resistors installed in the rear turn signals.
I also must report no issue with the C.C.
Old Oct 15, 2022 | 07:26 PM
Radco's Avatar
Steve how are those bulbs doing ?
any issue yet ?
How long have you been using them ? A few months if I remember!??
Thanks
Old Oct 16, 2022 | 04:25 PM
I installed those last October 15, 2021 and they work great, nobody has flashed me yet!
Old Oct 24, 2022 | 11:35 PM
chaosdsm's Avatar
thanks
I installed Hikari VisionPlus H13 LED bulbs in my 2010 1LT back in October 2020. Great beam profile & HUGE improvement over stock or premium (like Sylvania SilverStar Ultra's) halogen's & they're not even the bright version of the Hikari line!
skip to 3 minute mark to see halogen vs Hikari LED beam pattern - those are the Ultra bright Hikari which are supposedly 3000 lumens brighter than the ones I bought.
If you go with LED, be sure to get the Anti Flicker Resistor's for them as well.
