RPMs in 5th gear
Old Feb 6, 2018 | 04:40 PM
UltraviolentDroog's Avatar
RPMs in 5th gear
Greerongs, first post.
bought 07 HHR LT 2.4L 5sp
Question what speed does the HHR supposed to be at 3000rpm in 5th gear. I'm at 70mph. Seems high or is it just me.
Thank you
Old Feb 6, 2018 | 06:05 PM
Welcome to the site, I’m sure a member with a 5 speed will chime in.
Old Feb 7, 2018 | 04:30 AM
Although my SS has a different 5 speed than the LS, LT HHR's, it runs about 2900 RPM's at 70 mph.
Old Feb 7, 2018 | 05:04 AM
Cat Man HHR's Avatar
Use this, you have to know tire diameter, trans gear ratio and rear end ratio.
RPM/MPH From Gear Ratio Calculator by Wallace Racing
Old Feb 7, 2018 | 05:11 AM
Thank you
Thank you
Old Feb 7, 2018 | 05:13 AM
How do I find that out?
Old Feb 7, 2018 | 07:26 AM
Look up the specs on the cars trans gear ratios, final drive (rear end) ratio and use a tire size calculator from a web site to know the diameter of the tires you have.
http://media.gm.com/media/us/en/chev...2009.tab1.html
https://tiresize.com/calculator/
Using the first calculator given the results are with using a 215/50R17 tire:
Using Transmission Gear Ratio: 0.69 gives these RPM data:
Engine Speed (RPM) MPH 4.17 Gear MPH Gear MPH Gear
8000 RPM 210.93 MPH
7500 RPM 197.74 MPH
7000 RPM 184.56 MPH
6500 RPM 171.38 MPH
6000 RPM 158.20 MPH
5500 RPM 145.01 MPH
5000 RPM 131.83 MPH
4500 RPM 118.65 MPH
4000 RPM 105.46 MPH
3500 RPM 92.28 MPH
3000 RPM 79.10 MPH
2500 RPM 65.91 MPH
2000 RPM 52.73 MPH
1500 RPM 39.55 MPH
1000 RPM 26.37 MPH
rommer
Sep 23, 2012 10:49 PM
bad03xtreme
Aug 14, 2009 07:03 PM
acolddark0
Jul 21, 2009 08:18 PM
LT1GMC
Feb 11, 2008 08:30 PM
