Seat belt warning chime disable
Old Apr 13, 2006 | 12:24 PM
SoCalHHR's Avatar
Not for me!
Old May 26, 2006 | 01:48 PM
JAZZ-N's Avatar
I noticed yesterday that with the car off, the passenger door (And so I presume the other passenger doors) can open and it will still play (without a chime if I remember right) until the driver door is open.
Old May 26, 2006 | 03:10 PM
inchworm's Avatar
Dude, just wear the belt. You don't want to ride with me before your time.
Got my HHR on order [black, of course].
Old May 26, 2006 | 04:06 PM
rhoss1's Avatar
Brut,
I would like to disabled mine too, It bugs the crap out of me. If you find away to disabled it post it here so I can disabled mine.
Regards,
rhoss1
Old Jun 4, 2006 | 12:51 AM
jaybrd39's Avatar
Cool
I'm in my HHR with a seat belt on and ten Harley riders pass me going 75 mph. Now here is my gripe ,no helmets ,tank tops, shorts and sandles . Seat belts should be a choice, not forced by a law.
Old Jun 4, 2006 | 01:08 AM
  #26
cj krause's Avatar
Originally Posted by SoCalHHR
If you want to retain your stock stereo, simply remove it and unplug the harness. Next, pull the harness cable out a bit for access, and cut the dark green wire running to pin 5 on one of the two plugs. This wire transmits the GM Serial LAN data (chimes for seatbelts, lights on, door open, etc.)
Make sure you cut the correct wire. If you cut the wrong one by accident, just reattach it with a butt connector and try again.
Hope it helps,
So if i cut the dark green wire, the Onstar will not work?
you said it transmits the GM serial LAN data.
Old Jun 4, 2006 | 01:21 AM
  #27
guido099's Avatar
Everything goes trough the radio. Here is a tidbit kinda on this topic, if your enter your hhr trough the passenger side door and start your car w/ radio on, turn off car and exit trough passenger side the radio stays on. On mine anyway, anyone else try this?
Old Jun 4, 2006 | 02:05 AM
  #28
SoCalHHR's Avatar
The radio will turn off 10-minutes after the ignition is switched off - or when the driver's door is opened. This is to prevent excessive battery drain.
It's in the owner's manual.
Old May 8, 2007 | 10:28 PM
  #29
PANEL1stnGA's Avatar
So after all those postings does anyone know how to just turn the chime off?? i would realy like to turn mine off to ... i was able to do it in my last truck
Old May 8, 2007 | 10:33 PM
  #30
Yes. Just buckle up!!
