Side marker replacement
How does one replace the bulb in a side marker on a 2006?:confused:
For the front, you have to open up the wheel well to get access to it. It's the same for the front signals and headlights..
For the rear, you need a phillips screwdriver. |
If you have access to new "christmas tree" clips, it makes life much easier. That way you don't have to worry about damaging the old ones.
i recommend a $7 plug puller tool to get that wheel well liner out/ When i was tinting my fronts, i tried and fought with a screwdriver, but with the right tool it rook 30 seconds. it looks like this >------[||||]
Originally Posted by twistrman
(Post 450404)
Originally Posted by solman98
(Post 450410)
You used a screwdriver? I use a pair of needle nose pliers. They pull right out.
i was trying to keep them in tact, and the little slotted pry tool does just that.
(Post 450422)
use a pair of side cutters just be careful not to cut the push fastener
With the pliers you guys just grabbing from the side and pulling straight out or rocking it or what?
Goose |
