Side marker replacement
Old Mar 15, 2010 | 09:32 AM
scuba05477's Avatar
Unhappy Side marker replacement
How does one replace the bulb in a side marker on a 2006?
Old Mar 15, 2010 | 09:53 AM
solman98's Avatar
For the front, you have to open up the wheel well to get access to it. It's the same for the front signals and headlights..
For the rear, you need a phillips screwdriver.
Old Mar 15, 2010 | 09:58 AM
SmootHHR's Avatar
If you have access to new "christmas tree" clips, it makes life much easier. That way you don't have to worry about damaging the old ones.
Old Mar 15, 2010 | 02:09 PM
twistrman's Avatar
i recommend a $7 plug puller tool to get that wheel well liner out/ When i was tinting my fronts, i tried and fought with a screwdriver, but with the right tool it rook 30 seconds. it looks like this >------[||||]
Old Mar 15, 2010 | 02:34 PM
solman98's Avatar
You used a screwdriver? I use a pair of needle nose pliers. They pull right out.
Old Mar 15, 2010 | 03:45 PM
SmootHHR's Avatar
Ditto on the pliers
Old Mar 15, 2010 | 04:09 PM
twistrman's Avatar
i was trying to keep them in tact, and the little slotted pry tool does just that.
Old Mar 15, 2010 | 04:38 PM
urbexHHR's Avatar
Yeah, my dad has one of those...very nice!
Old Mar 15, 2010 | 06:19 PM
ballplr's Avatar
use a pair of side cutters just be careful not to cut the push fastener
Old Mar 15, 2010 | 06:34 PM
Goose's Avatar
With the pliers you guys just grabbing from the side and pulling straight out or rocking it or what?
Goose
