Since you've owned your HHR...
Old Feb 20, 2009 | 09:33 PM
Jersey Classic's Avatar
Oil Change every 3000 miles
Old Feb 20, 2009 | 09:38 PM
VictorySpark08's Avatar
Warranty: Bad Theft Deterrent Module. Upper Glove box recall.
Normal Service: Oil Change every 3K, Tire Rotation
6600 Miles.
Old Feb 20, 2009 | 09:46 PM
jmarines's Avatar
WARRANTY WORK:
Window switches not working, replaced bezal , miles: 468
Window switches still not working, replaced whole switch assembly , miles 940
pass front reclining level broke, replaced miles: 1078
rear hatch panel worped,replaced, miles:940
rear hatch leaking water when raining, replaced seal, miles 834
leaking water into the oil, replaced motor, miles:1483
front seal plate leaking, replaced seal, miles:3762
fuel line rupture, replaced fuel line, miles:4038
battery died, replaced battery, miles:5336
brake squel, installed kit, miles:5336
engine running rich, replaced injectors/fuel rail, miles:9421
o2 sensor , replaced , miles 9410
car overheated, replaced cooling fan , miles:9420
car overheated again, towed, could not find any problems, miles 9540
car overheated AGAIN, just got towed,will not start up again, miles: 9557
CURRENT MILEAGE: 9557
all regular maintence done.. oil changes, ect...
Old Feb 21, 2009 | 01:03 AM
MWG2's Avatar
I replaced the wife...she didn't like the HHR.
Old Feb 21, 2009 | 06:19 AM
monster5601's Avatar
2006
Steering column replaced.
A pipe in the air conditioner that growled was replaced.
Lift gate alignment.
Climate control panel replaced.
2008
LF tire TPMS sensor replaced.
Old Feb 21, 2009 | 06:31 AM
  #26
ballplr's Avatar
06 Lt bought september 07 with 16500 now has 31600
Passenger door lock which needs to be done again
Replace armrest's
Need to take in for blower motor making noise
Turned rotor's myself on car but vibration came back will replace rotor's later
Hate the way I can't see the radio and odometer in the day time if the headlights come on I think there is a bulletin for this problem but I can't find it
My A/C control lights flicker off and on from time to time but not enough for me to get the dealer to fix
Shifter replaced
The rest is just regular maint.
Old Feb 21, 2009 | 08:04 AM
  #27
2006 w/ 40K
Rear gate touch pad actuator replaced
Sunroof assembly replaced
Shifter assembly replaced
Battery replaced
Intermediate steering column replaced
Brakes resurfaced
Right front side marker light replaced
Left rear tail light bulb replaced
Right rear tail light bulb replaced
Old Feb 21, 2009 | 12:42 PM
  #28
JeffB's Avatar
Bought it at 23,095.
At 23,589 the drivers side seat belt stop button broke so they replaced both front stops.
At 23,755 installed Blizzacs.
At 25,409 the Check engine light came on.
Diagnostics said it was the exhaust cam shaft position. (what ever that means)
They removed the actuator cleaned the screen. (seems to have done the trick)
They also did an oil change.
Old Feb 21, 2009 | 01:20 PM
  #29
TomsHHR's Avatar
61,000k
Warranty
Runningboards
armrests
Need headliner support
Install dash latch
Deer Hits (5)
Lr door
Lr Quarter
Rf Fender
Rf Headlight
Hood
Windshield
Repair roof dents
Old Feb 21, 2009 | 02:47 PM
  #30
mongo's Avatar
Head impact recall and glovebox thingy.
Right front wheel and tire, pothole damage
13,000 miles, 3 oil changes.
that's all.
