Since you've owned your HHR...
Old Feb 24, 2009 | 12:49 PM
  #41
Jdans431's Avatar
BCM Reprogrammed and throttle body replaced. Thats it other than oil changes and routine things.
Old Feb 24, 2009 | 10:29 PM
  #42
Hotrodbob's Avatar
Just oil changes...19,000 miles and not a single issue.
Old Feb 25, 2009 | 09:57 PM
  #43
chevyorange's Avatar
Originally Posted by chevyorange
Nearly 22,000 miles. The last oil change per DIC was nearly 10,000 miles. I use synthetic.... should I trust this thing?? The oil looked good and it didn't lose a drop. I trust GM, but at 10,000 miles I still had 7% remaining life according to DIC.
The car is at the dealer right now for:
1. 22,500 mile service.
2. Burning rubber smell after a drive.
3. Vibration in steering (I played dumb, I know this is rotor problems).
4. 2nd remote being replaced (1st one has already been replaced).
5. Tire rotation.
6. Paint chips on hood (caused by wiper on driver's side when pulled out. Chipped the leading edge of the hood. Paint chipped on leading edge of driver's door (door scraped on its own mechanism inside the hood/fender).
I've had a rental since Tuesday last week and have no idea when I'll get my HHR back. I miss it.
OK - total cost was $85 for tire rotation and synthetic oil change.
Under warranty this time they fixed the panels, the chipped paint, turned the rotors, gave me a new 2nd remote. No news on the burning rubber smell... how could they not smell it!!!
Old Feb 25, 2009 | 10:37 PM
  #44
Uma's Avatar
Uma
''06'' 2LT, 26k miles. Hasn't been in yet. Lucky, I guess, waiting for something to go wrong to get the recall done, but not until! Todd (Uma)
Old Mar 6, 2009 | 02:21 PM
  #45
iuvenesco's Avatar
it has 42k miles on it now and I have to replace the brakes they are junk again, dealer fix do nothing, and rattle came back originating from the front stabilizer bar so I have to fix it myself
warranty service history
- MOTOR AND/OR FAN, BLOWER - R&R OR REPLACE 32739 miles
- REPLACE FRONT BRAKE PADS AND ADD SPLASH SHIELDS (INC REFIN 22826 miles
- STABILIZER SHAFT LINK REPLACEMENT 12487 miles
- LINK OR BUSHINGS, FRONT STABILIZER SHAFT AT CONTROL ARM - 12487 miles
- FRONT BRAKE ROTOR REFINISHING 7810 miles
- EVAPORATIVE EMISSION CANISTER REPLACEMENT 7507 miles
- POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 7507 miles
Old Mar 6, 2009 | 05:09 PM
  #46
Rcflyboy's Avatar
17710 miles so far. Had rotors turned at 700 miles, Reprogrammed cars computer because the tire sensors and door remotes quit working at 15910 miles.
Old Mar 6, 2009 | 07:52 PM
  #47
MWG2's Avatar
At 22,500 miles, dash fan replaced (for Heater & A/C air movement in cabin).
Old Mar 6, 2009 | 09:10 PM
  #48
hyperv6's Avatar
Has the Vacuum pump TSB done and that is all. All is running fine. 7 month since I bought it.
The Vacuume Pump works great I have full power brakes now at start up. This was a very good fix.
Old Mar 6, 2009 | 09:23 PM
  #49
ewg53's Avatar
2006 Silverstone LT2 33,000miles
Oil changes
Windshield
Tires
Steering Column-Warranty
Rotors & Pads
Gas
Tail light bulb
Old Mar 6, 2009 | 09:55 PM
  #50
urbexHHR's Avatar
Originally Posted by ewg53
Gas
You had to put gas in yours? That sucks!
