Solid Performance Engine Mounts
Old Dec 16, 2008 | 12:29 PM
DLVRNIT's Avatar
Originally Posted by prod
These would probably be for the SS (sporty minded folks), I do believe the 2.0 mounts are significantly different from the 2.2/2.4.
HMM,
Kinda thought they would be one in the same ? Like I tell the Wife, "That's What I Get for Thinking" !
Happy Holidays,
Old Dec 16, 2008 | 04:41 PM
TurboTechRacing's Avatar
Former Sponsor
Well believe it or not they are the same as the cobalt :)
We have them on sale right now @ www.TurboTechRacing.com
Manual trans upper engine mounts are $149.99
Auto trans upper engine mount are $189.99
Cobalt manual trans uses the same mount as the HHR manual trans
Cobalt auto trans uses the same mount as the HHR auto trans
We have both ready to ship.
These will help get the power to the ground and help eliminate power loss through sloppy stock mounts. Only side effect is slight vibs at idle.
You may look on www.TurboTechRacing.com under the "cobalt/drivtrain" or you may PM us for more info.
Old Dec 18, 2008 | 01:15 PM
Former Sponsor
TTT Thanks for recent orders, please post when you order.
Old Dec 26, 2008 | 06:34 PM
Former Sponsor
TTT Bump, please post when you order.
Old Jan 3, 2009 | 06:37 PM
Former Sponsor
Thanks for all the supporters who have recently purchased.
Old Jan 4, 2009 | 07:16 AM
mistermike's Avatar
If any of you have ever had solid mounts on a daily driver, you may be in for a big disappointment. The vibration transmitted to the body is often staggering. Some cars are worse than others, but the Ecotek isn't a particularly quiet motor.
There is no loss of power through a flexible motor mount. Generally, racers will go to solid mounts or torque chains to keep from breaking rubber mounts at launch. The price you pay for solid mounts is a lot more shock transmitted to the rest of the driveline. The tires become easier to break loose, and gear and bushing wear is increased due to the loss of "cushioning" in the elastic mounts. Polyurethane mounts are a reasonable compromise and are usually not annoying, depending on the durometer of the poly compound used. An Ingalls "stiffy" is also a possiblity if they choose to make one for this platform.
Old Jan 4, 2009 | 04:45 PM
Former Sponsor
Very little vibrantions from these mounts. Many cobalt owners state that they hardly even notice any
FYI these are not 100% metal to metal solid.
These would be the poly style. The Ingalls is a poor choice as MANY cobalt owners bend the brackets in the kit. The Turbo Tech Racing Mount does not have any structural issues.
Old Jan 4, 2009 | 05:02 PM
stranger's Avatar
Had a stiffy in a Honda and it was the way to go....there was vibs but to me the bad was worth the good.......if they would come up with a stiffy I'd be first in line.....short throw, sway bars....yeah would be nice BUT GIVE ME A STIFFY.....d@mn now that just don't sound right.
Old Jan 4, 2009 | 05:05 PM
Former Sponsor
The Cobalt stiffy will work on the HHR, as long as you get the "air box" out of the way.
Again it is not the most recommended product. Many purchased the Ingalls, and then replaced it with the Turbo Tech Racing Upper engine mount. They stated they would never go back to an Ingalls.
Old Jan 4, 2009 | 05:26 PM
stranger's Avatar
How 'bout a SS ?????????
