Solid Performance Engine Mounts
The TTR mount will fit with no modifications (it is about the same size as the stock one)
The ingalls will not fit the SS without an aftermarket intake, so the stock airbox is not in the way.
Well if the turbo tech is polyurethane, then I bow to more experienced users here. I've got poly mounts on my GTO and there's no obnoxious vibration. I've ridden in many cars with solid mounts, and they will rattle your teeth out.
Yes you do not want metal to metal mounts, these have a little bit of urathane to keep your teeth in place.
