SS Half Shaft
Old Sep 28, 2020 | 11:22 AM
PulpFriction's Avatar
SS Half Shaft
Can't find anything loose yet in my front suspension, but the inner CV joint on the passenger half shaft seems to have 2-3 degrees of play, regardless of angle. Only additional play seems like normal gearbox lash but I'm kinda new to this car. Haven't checked the drivers side yet.
2010 SS 5-sp performance package (so with limited slip differential) 110K miles.
I'm not up on the current parts availability scuttlebutt.
Thoughts?
Edit - adding somewhat irrelevant pics because why not?
Last edited by PulpFriction; Sep 28, 2020 at 11:29 AM. Reason: add somewhat irrelevant pics
Old Sep 28, 2020 | 01:57 PM
Play like that is normal, but see if the other side it similar.
Old Oct 11, 2020 | 02:11 AM
Same on the other side. About 1/4” at the disc radius. I’m no expert but don’t understand the reason for it.
Engine and trans mounts are shot.
Old Oct 11, 2020 | 07:16 AM
TTR has poly mounts!
Old Oct 11, 2020 | 11:04 AM
I like my TTR mounts!
Old Oct 17, 2020 | 11:54 AM
Yeah, this car is just for the street. For now. I don't want wheel hop but I don't want vibration either. Got an OTTP motor mount. Thinking about a stock mount set, So if I don't like the OTTP I'll have a ready fix.
Last edited by PulpFriction; Oct 19, 2020 at 11:36 AM. Reason: Typo. Always typos.
Old Oct 17, 2020 | 01:23 PM
Cat Man HHR's Avatar
I'm slow, what is OTTP ? Thanks.
Old Oct 17, 2020 | 01:48 PM
Lonwane's Avatar
As for the end play, It is similar to wing flex on airplanes.
If it wasn't there things would break.
Old Oct 17, 2020 | 02:34 PM
Google search, ottp mount.
Old Oct 18, 2020 | 11:51 AM
Are the OTTP mounts still available? I know TTR mounts are!
