SS rear spoiler
SS rear spoiler
does anyone know if the rear spoiler (flushmount) found on the SS models is only a bolt on? or does it come 3m double sided tape? Ive read on another post that somebody cut off the bolts and only used double sided tape, how would that hold up? would it be enough to hold it on there?
Sure it'll hold for awhile, then at some point let loose and maybe blow off going through the winshield of another car hurting or even Killing them.
Do it Right, or Don't do it at all.
just wondering because considering the chevy emblem is held on with double sided tape and that is VERY hard to take off..
im just scared of drilling holes into my car
and then possible moorreee rust-able area lol
Lets put it this way.
Tape it on you have less than 50% chance it will remain on. Bolt it on you will have a 100% chance of it remaining on.
Tape on an emblem is not the same as it is for a larger body part. Also many time people never get the surface clean enough to let the tape stick well. Too many of the Lund Scoops we sell come off due to poor prep.
If you are going to do this do it right and bolt it on. If you can't do it spend the money and have someone do it for you. You will save buying another one and repainting it after it comes off and gets run over.
