sticky lock actuator
Old Nov 20, 2012 | 09:00 AM
maier748's Avatar
Has anyone had a problem with the automatic lock actuator? My driver's door is sticking, and I am wondering how difficult it is to replace, or is there a fix?
Lubrication, etc?
I do not want it to quit altogether, as I don't want to crawl out the passenger's side.
Thanks in advance for any help.
Old Nov 20, 2012 | 10:06 AM
There have been many posts that mention that same problem. The general opinion is it's not the actuator but the rod or knob that binds.If you can hear it try to work when you push the fob, then the actuator is probably OK.
Some have ground out the hole where the rod comes through. Some have changed knobs to a skinnier one. Some have sprayed lube down the rod hole.
My personal fix: Move the knob up and down by hand 20-30 times. It seems to free it up. I only had an issue with it at 1 year old. Did the up and down fix and been trouble free for 2 years.
Old Nov 23, 2012 | 02:07 PM
maier748's Avatar
Thanks
I am on my way to the garage to give it a try.
Thanks
Old Jan 21, 2013 | 07:56 PM
mister hhr's Avatar
Mine has this problem as well I will have to try this.
Old Jan 21, 2013 | 10:20 PM
Mrs. DLVRNIT's Avatar
yeah the door panel/lock knob hole may need to be opened up a bit .. if you remove the knob and it now actuates freely then that is your problem ..
Best-O-Luck ,
Old Jan 22, 2013 | 05:16 PM
Black Box's Avatar
My passenger side door lock was doing this, so we took the door panel off and found two things. 1st problem-The hole in the door panel where the lock comes through had a huge burr on it, we used a round file on it and enlarged the hole slightly. The second problem was actually the factory sound deadener board, It was putting a lot of pressure on the side of the rod. We cut a tiny slit over the rod, and it relieved the pressure on the rod.
Problem fixed, 2 months and counting!!
jayweston
Jul 12, 2014 03:01 PM
Babbette
Jan 11, 2014 07:27 PM
pitbull76
Oct 9, 2011 01:42 PM
1970judge
2.4L Performance Tech
Mar 2, 2010 09:23 PM
Markiemark
Mar 12, 2007 01:36 PM
