Stubby Antenna
Old Jun 5, 2007 | 11:39 AM
Mine had no issues like that. Be very careful NOT to get any locktite on thew plastic it will weaken it.
The thread on the antenna is deep, much deeper than I needed. I put the post on the base first, then screwed the antenna on.
Old Jun 5, 2007 | 11:50 AM
Goose's Avatar
Duh....why didn't I think of that? Ok off to take it off and do it that way...sometimes I'm amazed I make it through the day
Thanks
Goose
Old Jun 5, 2007 | 11:51 AM
Dan's HHR's Avatar
I've done it on mine but with an antenna from an 07 Chevy Equinox, It works good and good reception
Old Jun 6, 2007 | 05:25 AM
Goose's Avatar
Well I have it on there and it is official..the reception stinks! WEEI in Boston which is a pretty strong signal fades out just before I cross the state line back into NH now...that never happened before. Couple other stations are crackly now also...but it looks good lol
Maybe I'll try some of that Radio Shack stuff but I'm skeptical
Goose
Old Jun 6, 2007 | 06:07 AM
GCarp's Avatar
Is it possible the loctite is insulating the connection?
Old Jun 6, 2007 | 06:18 AM
  #26
Goose's Avatar
No..it shouldn't..in fact you can barely see any on there at all
Goose
Old Jun 6, 2007 | 09:52 AM
  #27
For those yet to do this, do not use locktite! If you get any on the plastic it will weaken it and the antenna base will crack.
Don't know why your reception is so bad, though any stubby will be worse that the OEM. Hope you get it worked out.
Old Jun 6, 2007 | 10:45 AM
  #28
Goose's Avatar
I didn't get any on the plastic afaik...I only put a tiny bit on the threads that go into the antenna...it isn't horrible reception..I can still get stations..just not as far away from Boston as I used to.....not a huge investment...if it bothers me too much I'll just put the OEM back
Goose
Old Jun 6, 2007 | 11:34 AM
  #29
sjssk's Avatar
That is why I keep my fishing pole on!
Old Jun 6, 2007 | 12:04 PM
  #30
Black Rose's Avatar
That's why I have XM
Rarely listen to AM/FM anymore.
