Chevy HHR Network
-   General HHR (https://www.chevyhhr.net/forums/general-hhr-4/)
-   -   Suggestions… (https://www.chevyhhr.net/forums/general-hhr-4/suggestions%85-64509/)
Gearhead1 Jul 17, 2021 07:50 PM
Suggestions…
Here is what I need to do…..I have to run a flat 4 trailer wire from the front of my 2011 HHR to the rear lights. So what the best way to route the wire under the car out of harms way and then inside to the existing tail lights
donbrew Jul 17, 2021 07:58 PM
What's wrong with under the carpet with all the other wires?
Gearhead1 Jul 17, 2021 09:20 PM
I could do that I guess….only issue with that is I would have to come thru the firewall with it some where. I really dont have a need the wiring inside the car although it would be protected that way. Con is….be another potential leak.
Silverfox Jul 17, 2021 10:54 PM
Just use a quality silicone sealant @ the entrance point.
Clean the surface around the hole with alcohol or acetone if it is factory paint before sealing..
I use Marine clear silicone.
Silverfox
Gearhead1 Jul 18, 2021 07:55 AM
anyone know if there is a rubber bulkhead grommet to route my wires thru in rear of the car?
firemangeorge Jul 18, 2021 08:38 AM
Yep. Several back there.
donbrew Jul 18, 2021 08:52 AM
What wires need to go through the firewall? The BCM is right there with spare fuse positions.
Oldblue Jul 18, 2021 09:51 AM
Curt and I’m sure other suppliers have plug and play harnesses. Easy to install and run the harness out the hatch to the trailer wires
https://www.chevyhhr.net/forums/how-...-wiring-32903/
Now if you’re connecting to the tail lights to harness up to a motor home in a flat tow set up, that should work just disconnect the HHR body side of the light harness.
donbrew Jul 18, 2021 01:18 PM
There are wireless options, too. Cheaper than the wire.
I meant the brake/tail lights are controlled by the BCM, no need to run wires to the rear.
Gearhead1 Jul 19, 2021 06:25 AM
that is exactly what I have in mind….with diodes to prevent back feeding to the rest of the car’s wiring harness. Just need best location to route the flat 4 trailer wires.
