Temp guage
Old Sep 15, 2008 | 10:37 PM
Jeda13's Avatar
Temp guage
Anyone have their temp guage stop working or sometimes work on the HHR? Mine is random. Sometimes it stays at the morning reading, other times it doesn't. Aside from air leaking out of my front tires, I'm thinking of taking her in.
JIm
Edit: Outside Air Temp...sorry
Old Sep 15, 2008 | 10:41 PM
oneton's Avatar
Air temp or coolant temp.
Old Sep 16, 2008 | 05:54 PM
TopWop's Avatar
My 08 HHR has been in 3 times to the dealership for this fix and the DIC still dont read even remotely close to what the outside temperature is.
Other than that, I do like the HHR alot.
Old Sep 16, 2008 | 06:02 PM
HHR4JK's Avatar
welp my outside temp....... stuck again......... this time it stayed stuck till i got to the dealership..... they did some checkin and testing ....... the end result is they had to order a new bcm, said that was the problem..... welp i guess in couple days take it back see it that works.....
but my worked then it didnt .......then it would work...... stay the same temp for miles and miles...then all of sudden change....... did that several times. but finially stayed stuck to the dealership.
Old Sep 16, 2008 | 07:32 PM
Jeda13's Avatar
Exactly. I know it's not a necessary feature but it is nice. Plus, it doesnt' put a lot of faith in the other readings I'm getting and those are more important.
Jim
Old Sep 16, 2008 | 10:18 PM
chevyorange's Avatar
So, not sure if I read correctly, but have you had the replacement in yet? I'd be interested, mine reads about 5 to 10 high sometimes. Again, not important... but it would be cool if it worked!
I can verify that my compass is good though! :)
Old Sep 17, 2008 | 12:30 AM
Black Raven 2008's Avatar
Oitside Temp Gauge
Mine has never worked and GM will do nothing about it !
Wont replace the BCM and wont repair grinding rear brakes !
I am fed up with GM.
Old Sep 17, 2008 | 12:37 AM
Snoopy's Avatar
Did you speak directly with a GM person OR is that the dealer that is denying service??
Old Sep 17, 2008 | 01:29 AM
Dealer
The dealer says they contacted GM
Old Sep 17, 2008 | 05:57 PM
Snoopy's Avatar
Then Black Raven by all means utilized the Customeer Service phone number in the rear of your Owners Manual.
Remember the Customer Service people are NOT GM personal (it's a contracted service), although they essentially represent GM. Have your documents/facts in front of you and express your concern and disappointment in the dealers inability to repair a possible safety defect (rear brakes). You didn't indicate WHY you needed a NEW BCM but, depending on the need, I believe they can be reprogrammed. Was that done and for what? Results....?
IF you have any problem at all and the dealer acknowledges the problem but is unable, on their own inititive, to complete a satisfactory repair.......they then will contact GM for information/assistance. I can't believe GM said don't help this guy !!! . Now if the dealer cannot find anything in your complaint, no grinding, no dragging, etc., that is an entirely different issue.
