Time for a smoke test - P0171 issue
Old Sep 4, 2022 | 02:43 PM
If you smell it under the hood, makes flex pipe sound suspect. You should be able to hear it if you rev up with the hood up.
Fuel smell or more like solvent?
Old Sep 4, 2022 | 07:34 PM
greg8453's Avatar
Have you checked fuel pressure under load?
Old Sep 5, 2022 | 02:33 PM
BERNS's Avatar
Originally Posted by Oldblue
The purge valve under the hood should be closed both directions. You should not be able to blow air thru it .
Thanks. Attached my mityvac to the purge valve as shown on the attached video and there was not vacuum loss. looks like it checks out.
Old Sep 5, 2022 | 02:40 PM
BERNS's Avatar
Is that after it warms up or only upon startup?
I would inspect the fuel system from end to end under pressure and eliminate a fuel leak before going after an evap leak with smoke. The fuel line (as well as the evap line) is notorious for leaking due to corrosion, in particular near the lr wheel, but anywhere from the tank to about mid-cabin. There are some small foil-wrapped insulation blankets that can soak up the fuel, preventing tell-tale puddles on the ground.
The fuel system should hold 55-60 psi after shutoff, for, idk, 10 minutes? I don’t remember. If it doesn’t, it could be a bad check valve (in the fuel pump I think,) but if not it’s probably a fuel line leak or a leaking injector.
It is at start up. It starts up at first try with no issues whether hot or cold. Will try the full test with load per the attached video to see if it also checks out. Without load, it holds pressure.
Will lift car and look at all the lines but doubt rust cause I live in Cali but never know. Thanks for the tip and location to look.
One thing that I do notice is that upon start up, it revs up like it sucked additional air for a few seconds then idle settles. Suspecting intake leak cause it is starting to act like a Monte Carlo that I used to have that have intake manifold leak. It also shakes when idling as it wants to stall but it does not since I think the ECU is compensating hence why it is running rich.
Old Sep 5, 2022 | 06:02 PM
greg8453's Avatar
https://www.youtube.com/watch?v=-MaaY_o6vPQ
That would be for a P0172 rich code if that were the problem. You have a lean code.
Old Sep 5, 2022 | 06:04 PM
greg8453's Avatar
https://www.youtube.com/watch?v=_oXLUqE4Sf0
You have rich and lean codes both?
Old Sep 5, 2022 | 07:20 PM
So, nobody reads. Fuel TRIM system lean not A/F ratio lean.
Old Nov 1, 2022 | 01:47 PM
BERNS's Avatar
Hello All,
Apologize for not being on. Had a family situation with a risky pregnancy that I needed to switch my attention to. Thankfully, we now have a new healthy baby boy.
Going back to my issue, this morning I hooked up smoke machine through brake booster hose and held it, built up pressure via the intake tube where the air filter is connected but it did not smoke anywhere in the engine bay.
Performed fuel pressure test, connected and just turned key to prime pump, it reached 55 psi, let it stand for 10 mins and it dropped to 52-53 psi, is that normal? I then proceeded to start it up and ran it, held pressure at 60 psi with no issues and when I revved it up it would drop a bit like the video I previously posted. Let it idle and it stayed at 60 psi.
Tried smoke test via muffler to see if it reached but disconnected as soon as it started smoking since the muffler has a few gashes. Will need to replace soon as well.
Seems that I will have to go back to the exhaust flex pipe and look at it more in details and see if there are any loose bolts... it is a 2006 so it might be due for some tightening of some bolts...
Old Nov 1, 2022 | 02:02 PM
The smoke test indicated is the EVAP system.
Could be a rusted out EVAP vapor line or fuel line. The usual place for both is under the plastic hold down in front of the driver side rear wheel well.
Fuel pressure should be around 55psi and only loose 1-2 psi for 5 minutes after shut down.
Old Nov 1, 2022 | 02:15 PM
BERNS's Avatar
Thanks. So there should not be any smoke coming from the intake elbow before the MAF? I had to put a glove on mine like the attached video (play at 2:40) and it was building pressure but there was no smoke anywhere from any seal.
elbow and glove at 2:40
