Originally Posted by HB2
(Post 944009)
My '06 2.4L does this also. It throws a "cylinder 4 misfire" code, and with a diagnostic read, #4 is misfiring. I replaced all four plugs; all four coils; intake manifold gaskets, but it still throws the check engine light and cylinder 4 misfire code. I see below, camshaft sensors may be my next move.
What exact plugs and coils did you use in replacement? The p/n's. Did you happen to do a compression check when the plugs were out? How many miles on the car? Any prior or other history of engine problems? Strongly recommend you get hooked up to a capable scan tool, one that will read all codes, not just P codes, and post the numbers here. All of them, even if you think they're unrelated. |
Is P0304 the only code? Anything you assume is not relevant.
Have you done a compression and leakdown test? |
If it's not a plug or a coil, the other possible culprits are an injector or gunk in the fuel rail, or a mechanical problem (diagnosed with the compression or leak down test that donbrew mentioned.
Those are the numbers on the scanner while engine is running.
No other codes and no compression test or fuel rail cleaning, yet.
