Transmission Cooler Install...Anyone Do?
Old Jun 17, 2007 | 06:43 PM
KZig's Avatar
I have a 2LT with Auto, 2.4L that I am trying to install a Hayden brand transmission cooler. My problem is I can't find the proper adapters that will fit onto the existing lines that run into the radiator. Has anyone installed a cooler and where did you find the right adaptors? Thanks.
Old Jun 17, 2007 | 06:45 PM
Size:  5.6 KB to the site!!! I remember members talking about these but don't recall anyone actually doing one.
Old Jun 17, 2007 | 07:18 PM
Black Beauty's Avatar
Go to a shop
Be very careful, if you proceed, the trans is a sealed unit, any lose of fluid especially if you`re adding additional piping, could cost you a trans, not to mention void your warranty.
Old Jun 18, 2007 | 07:43 AM
Dan's HHR's Avatar
Old Dec 4, 2007 | 05:49 PM
mew7789's Avatar
Been a while since this was posted. What about it? has anyone done it? I would like to do this as well. I know the new fluid is not as easy to boil but this seems like cheap insurance against overheat.
Old Dec 4, 2007 | 06:39 PM
an08HHR's Avatar
My thoughts also. If something can be done, there is always someone who will somehow get er done
Old Dec 4, 2007 | 07:00 PM
oneton's Avatar
Just be careful not to cool to well. unless you tow a lot with your HHR, [Tow with a HHR????] a trans temp gage would be better.
trans fluid like eng. oil has a operating temp that it should run at and the cold can be as bad as over heat IMO: my 2cents:
Old Mar 14, 2008 | 05:10 PM
mew7789's Avatar
I just saw a B&M cooler that claims to automatically bypass the cooling element when the fluid is cold. Must be something to what you are saying. The transmission is not actually sealed. It has a plug for changing the fluid but no dipstick. I do wonder how you would get the level right because your capacity would have to go up with the additional tubing. I think as soon as my warranty is up I'll just install the B&M. It requires cutting the hose (universal kit). I tow a small utility trailer occasionally and even though it is not overloaded I still like a cool tranny.
Old Mar 16, 2008 | 08:22 AM
Desert Coyote's Avatar
I just had a Continental Transmission shop put one on Stitch II. Thus far, doesn't seem to be having any issues in regards to either leaking fluids or tranny getting too cool. (Plus, it didn't cost too much, a little over $200 for parts and labor because it was easier than they thought it would be.)
Old Aug 9, 2015 | 12:22 PM
ramseyjo68's Avatar
Very simple to do. I put one on mine and it took me about an hour and half to do. I went with a Hayden Automotive 676 Rapid-Cool Plate and Fin Transmission Cooler from amazon along with a Hayden Automotive 397 Transmission Line Fitting Kit. The lower line on the bottom of the radiator is the return line to the transmission. I installed the fitting kit in to that then ran it to the external trans cooler and then ran the return back to the transmission return. really quite simple to install, the only thing that was a pain was trying to check the transmission fluid to make sure that it was still okay. If i could figure out how to post pictures I've got several that I could share.
