Turbo Tech's 1" Sway Bar
You should get it, I had mine installed by Don after Cisco's Brunch earlier this month. Even without leveling springs and even at normal speed turns, the difference is an improvement. There seems to be less of a wallowing wiggling of the rear end. "point and shoot" so to speak
Trust me your tires will loose traction "friction" just as easy as before (wont change before or after the install)
Sway bars help in cornering when your tires are stable.
I'm aware of that. What I'm wondering about is will the arse be more likely to come around on me or no?
