valve change
Old Feb 22, 2007 | 06:31 PM
dixiesHHR's Avatar
valve change
I did not have much to do today so I went out and changed the clintanary valves on the wifes HHR. I think the preformance went up by 10 to 15 percent. Just wondering if any one else has done this. Not hard to do. While doing this I also put in new muffler bearings and rotated the air in the tires. Not any improvement in performance but it does look better.
Old Feb 22, 2007 | 06:43 PM
hhrmajesty's Avatar
You should have changed the blinker fluid too.
Old Feb 22, 2007 | 06:47 PM
Pizzaman's Avatar
A little K9P will also give you a good kick in the pants!!!!
Old Feb 22, 2007 | 08:05 PM
ewg53's Avatar
You can also change the halogen fluid on your headlights it makes the light look a lot whiter than stock fluid.
Old Feb 22, 2007 | 08:32 PM
dbarberaz's Avatar
I tried this and could not get all the air back in. How did you keep the air from getting away?
Old Feb 22, 2007 | 09:14 PM
Applenut's Avatar
Try reversing the polarity, my first car ran better with a positive ground. (1955 Studebaker Champion)
Old Feb 23, 2007 | 11:11 AM
GCarp's Avatar
Might have to check with the ID10T programmers to get the performance of the DIC upgraded.
Old Feb 23, 2007 | 11:16 AM
dixiesHHR's Avatar
Its not legal alter the DIC in Utah. We have some strange laws here. You even have to have a reclaim system when you change the air in your tires.
Old Feb 23, 2007 | 04:30 PM
GCarp's Avatar
But I figure I can get at least 2-3 MPG with the right adjustment.
Old Feb 23, 2007 | 04:40 PM
PhxHHR's Avatar
I've personally done this, and have seen a 12.7% increase in blinker speed and luminosity, both which have contributed to smoother turns.
Other similar mods include:
- I've decreased the granularity in the windshield for increased clarity
- I've switched the air between the front and rear tires; I did this because OEM specs call for the denser air in the back, but I disagree with this placement, as the (heavier) engine is in the front
- I've filled the pores of all zenith-facing leather with color-matched filler to help mitigate crumb build-up
Other performance-improving mods to come.
