Originally Posted by hurst2001
(Post 862299)
are they aluminum or steel I can’t tell .. https://www.ebay.com/itm/Two-Control...5/222792429478 |
Remember to double check the torque on those bolts, to be sure. |
Rebuilt! Nothing wrong with that, just inspect closely.
However, they should not list on eBay as new. I would try leveraging. |
Originally Posted by donbrew
(Post 862341)
Go to your local big box parts store and borrow the tools. Or use a hammer & chisel.
Remember changing old fashioned wheel bearings? |
Originally Posted by wildherre
(Post 862348)
Yes these are aluminum & have bolt in grease-able ball joints...The best deal that I could find..
https://cimg7.ibsrv.net/gimg/www.che...0382750c1.jpeg
I ended up just putting new moog problem solver bushings and ball joints on both sides. It cost me about $60 a side |
Gee my point , all along. New ball joints ( you only drill out the rivets once) then the bushings, a ball joint press rental or a large bench vice, I have used an air chisel and a BF hammer.
Why , because nobody provides those bushings installed. Well worth the effort, thanks for your time posting your method |
At first I really wanted to just get it done quick and buy the complete arms but I really wanted it to last so I decided to go the extra step and just rebuild with decent parts that are proven to last vs. Complete arms with questionable quality parts. The only thing that I found irritating is that I had to try 2 different style presses from the parts store that did not even want to work. Even the employees could not get them to seat correctly. Luckily I found a person with a homemade job that worked out perfectly with these bushings. This was made with a heavily modified pulley puller and a cut down large socket welded to it.
(Post 863314)
yea just got these it was a great price and the rear bushing look a little better then stock plus the ball joint has a grease fitting , not a bad price at all lookin at about 60$ apiece.. and fast shipping a plus .. https://cimg6.ibsrv.net/gimg/www.che...395869769.jpeg One one left is two inches and the other bolt that came with the control arm is 1 1/2 ... https://cimg7.ibsrv.net/gimg/www.che...501cbd3e0.jpeg |
What bolts? What happened to the originals?
