What gauge wire for horn replacement?
I am going to do a horn replacement and wondered if anyone knows what gauge the wire is before I get the wheel well taken apart?
I bought a dual note set so I'll have to wire in the add'l horn. Thanks in advance. |
It's 18 gauge.
Thanks man... I love this site! :thumb:
Originally Posted by a76marine
(Post 476198)
Amazon.com for under $20. Obviously I haven't installed it yet so I can't say what it's like but I did see some other members on here have purchased the same set as a replacement and I watched several YouTube videos where others had used this set to replace the horns on their vehicles.
I was deciding between two horns... the Wolo Bad Boy which is a small self-contained air horn and the Fiamm El Grande twin note horns. I chose the Fiamm El Grande since it's a direct wire in, no need to worry about fuses and you can even use the same stock bracket. |
(Post 476303)
(Post 476303)
I was deciding between two horns... the Wolo Bad Boy which is a small self-contained air horn and the Fiamm El Grande twin note horns. I chose the Fiamm El Grande since it's a direct wire in, no need to worry about fuses and you can even use the same stock bracket. Gas Man: Here ya go: https://www.chevyhhr.net/forums/show...t=adding+horns But you certainly do NOT need to remove the front bumper cover.. & plenty more using Search Box |
Do a quick search there are actually several threads on horn replacement already.
That's where I got the idea and the names of the horns to choose from. ;) |
Originally Posted by Gas Man
(Post 476438)
You going to start a seperate thread on this? I really would like to change the stock horn.
Just did and included pictures :nuts: https://www.chevyhhr.net/forums/showthread.php?t=30535 |
Awesome!!!
