What gauge wire for horn replacement?
I am going to do a horn replacement and wondered if anyone knows what gauge the wire is before I get the wheel well taken apart?
I bought a dual note set so I'll have to wire in the add'l horn.
Thanks in advance.
Thanks in advance.
Amazon.com for under $20. Obviously I haven't installed it yet so I can't say what it's like but I did see some other members on here have purchased the same set as a replacement and I watched several YouTube videos where others had used this set to replace the horns on their vehicles.
I was deciding between two horns... the Wolo Bad Boy which is a small self-contained air horn and the Fiamm El Grande twin note horns.
I chose the Fiamm El Grande since it's a direct wire in, no need to worry about fuses and you can even use the same stock bracket.
Gas Man: Here ya go: https://www.chevyhhr.net/forums/show...t=adding+horns But you certainly do NOT need to remove the front bumper cover..
& plenty more using Search Box
