horn replacement problem
I just replaced my stock horn with 2 late 50's auto-lite (VErY LOUD) horns but there is a problem. I keep blowing fuzes and it will not sustain a blast, just short beeps. The stock horn used 2 wires and did not require the horn be bolted to chassis to work. My new old horns only have hookup for 1 wire and get ground from chassis mount. Any ideas?
The stock horn uses a ground wire (Blk) which is connected to ground hence it does not need to bolted to the chassis, and the Dk GRN from the horn goes to a relay and fuse. The horn button connects to the BCM which activated the horn. It sounds like your new horns are pulling more than the 10A fuse can handle. I would wire up a separate circuit for the new horns with another dash mount switch as others have done, or add another relay to the circuit to supply power to your new horns (you would need to see a wire diagram to know where to install it). Not knowing how much current the OEM relay can handle, I would opt for a separate circuit. Other option is get a horn that draws less than 10A.
more info on my horn problem, the current horn relay is a 20 amp 14 volt. 3 questions
1. can that be supersized?
2. supposed to be a 10 amp fuze, currently using a 25. Is that going to booger something up?
3. anyone know what amperage a late 50's 12 volt pair of horns is or how to tell? A google search on auto-lite horns produced nothing usefull
more info on my horn problem, the current horn relay is a 20 amp 14 volt. How did you find that out? It is not marked on my relay?
3 questions
1. can that be supersized? Probably not, don't know for a fact. If the method you found out the relay is 14VDC 20A was from a manufactures data sheet, then ask the manufacturer.
2. supposed to be a 10 amp fuze, currently using a 25. Is that going to booger something up? You've gone way beyond my comfort zone for a fuse upgrade. Are you saying your fuse still blows with anything less than a 25A fuse? Use the smallest fuse that will not blow when activating the horn.
3. anyone know what amperage a late 50's 12 volt pair of horns is or how to tell? A google search on auto-lite horns produced nothing usefull Do you own measurement, don't rely upon some specification. Take an Amp Meter and using your vehicles battery with the engine running hook up the horns and measure the amps the horns actually use. Engine running so the voltage is up at operating level. Retest with the engine not running. Use the higher measurement. You can remove the Horn Fuse to do the measurement, put the Amp Meter across the fuse contacts.
3 questions
All in all the advise in post #2 above about designing your own separate circuit is the only way to correctly do this if you use your horn a lot. Only problem I have with his post is the BCM is connected in parallel so it can activate the horn for alarm purposes. The BCM does not activate the horn when the steering wheel button is pressed. Source: 2009 FSM.
Thanks all for all the great ideas. to answer snow white, the relay is dtamped on the top with the info.
I went to oreileys auto parts and actually found a fella that knew his stuff about electrical. He set me up with a 30 amp relay which i fed fron the engine compartment battery terminal. I put a fuze link in line between the battery terminal and the new relay and put in a 30 amp fuze. I put a10 amp fuze back in position 60 for the horn. I basically followed the instructions on the back of the relay pack for the rest of the wiring and all seems to work. I let you know if anything jickey happens.
