A/C problem
Old Jul 28, 2010 | 07:31 AM
06SILVERLT's Avatar
A/C problem
the a/c still continues to run after i push the little snowflake for it to go off
Old Jul 28, 2010 | 07:49 AM
ChevyMgr's Avatar
Is it set to recirculate?
Old Jul 28, 2010 | 09:52 AM
06SILVERLT's Avatar
yes it is and after i push button to turn a/c off but leave air on it still blows ice cold air and no the defrost isnt on either
Old Jul 28, 2010 | 12:03 PM
It should blow cold for a several minutes after shutting off the AC, that's normal. Does the yellow light go off when you push the button?
Old Jul 28, 2010 | 12:07 PM
ChevyMgr's Avatar
A/C will run if recirculate is selected. Doesn't matter what the lights are doing, as long as it is switched to recirculate or defrost the compressor will be running.
Old Jul 28, 2010 | 12:12 PM
goetylsd's Avatar
So, if I turn my car to "recirculate" every time I go somewhere, it's like I'm always running the air conditioning then?
Old Jul 28, 2010 | 12:25 PM
ChevyMgr's Avatar
Yes.
Old Jul 28, 2010 | 03:46 PM
goetylsd's Avatar
Oh, that sucks. I thought by running it on recirculate (which is actually really cold) instead of air conditioning, I was saving gas. Oh well, I guess I need air conditioning either way then.
Old Jul 28, 2010 | 04:22 PM
Laco's Avatar
Just don't run it on recirculate, let it draw in outside air, then you can turn the compressor off, and only use outside air to vent, at least if its cool enough outside to do so.
Old Jul 29, 2010 | 11:10 AM
06SILVERLT's Avatar
well i have to head out shortly and i'll try what you said and see if it makes a difference i'll be on after 3pm thanks
