Wolo horn problem
Wolo horn problem
I am having a problem with my wolo big boy horn. I have had it in where my original horn was for maybe 9 months and I just noticed it isn't as loud as it used to be and sounds like the may be an air leak. Any one have a problem like this? Any suggestions about what I should do?
I have emailed them but have not gotten a response yet.
Oh, missed that myself. My Bad Boy is 1 piece. What you call the The Big Boy should have a small interconnecting hose. Is the horn loose & swiveling on it's one bolt? Also check the ground to make sure 100% of it is grounded. With all the amps running through the horn a bad ground could be causing a low voltage issue.
Looks like it might have been the ground. After working checking all the ground wires, and crimping the ground wire on the horn tighter, it seems fine. But only time will tell. Thanks for all the advice. It really clued me in on what to look for.
Gas Man
"How To" Tutorial Library
11
08-09-2010 11:13 AM
