What goop/glue remover to use?
The goop remover I used on my HHR affects the paint. Does anyone know of a name brand of goop or glue remover that doesn't dull or affect the paint. I don't know the brand of glue used.
Boydie
Back in the Saddle..........................
Boydie
Depends on what you are trying to remove. I've used WD40 to remove adhesive left from stickers, emblems, trim etc. When you're done you just have to remove the oily residue with some type of soap/detergent.
I used Glue B Gone to remove residue from the dealer nameplate that I removed because it looked idiotic and I don't like promoting dealerships good or bad!
Glue B Gone did not affect the paint at all and very easily removed the residue. My car is Victory Red.
Thanks guys, I'll try WD-40 first cause I have some. Then if I need I'll try the glue be gone.
product called Goo Gone works amazing! and does not effect the paint at all
here is a link to walmart
http://www.walmart.com/ip/Homax-GG12...8-oz./21022179
