What's the HHR like in winter
Old Aug 31, 2019 | 09:51 AM
geg's Avatar
geg
Silverfox is right. I recommend Bridgestone Blizzak too. True, I doubt that the 215/60 R16 will be good for the front wheels - too big. Silverfox probably meant 205/60 R16.
I have been using Blizak for many years.
I had Michelin too - but I did not accept it. Michelin brakes very well, but lateral support is lower than decency. Active moving to the next row is simply scary.
As for the car itself - it is fully adapted to winter temperatures. My Hippo lives in the snow 7 months a year. It tolerates frost and snowy roads.
There are drawbacks, but they are not critical.
1. When starting off, the front wheels slip not only on ice, but simply on cold asphalt. You will have to forget about a sharp start from a traffic light;
2. At a temperature of -15 ° C and lower, the GM transmission fluid visibly thickens. Smooth movement in the morning until it warms up, or the risk of transmission failure;
3. The configuration of the brake fluid reservoir is not very good. At low temperatures, the word "brake" lights up. They say that on later models the reservoirs are already fixed and the car has ceased to scare the driver;
4. Aerodynamics mirrors unsuccessful. In heavy snow the mirrors are filled with snow very quickly. Have to stop and clean every 10 - 15 minutes.
That's all the problems. I did not see others.
Old Aug 31, 2019 | 10:01 AM
Silverfox's Avatar
Wren,
Bridgestone makes the Blizzak in 2 sizes that will fit your HHR.
205/50R/17
215/50R/17
If you want the narrower tire, go with the 205.
Michelin also makes the X Ice I3 in both sizes.
205 tread width 7.2"
215 tread width 7.6" .... Overall diameter is 25.5" so no problem fitting.
Geg,
I have the 215/60R/16's on my HHR and they do fit OK .... Close but OK.
In this State ..Washington I think you have to buy 4 new tires all at the same so you would have no unequals.....
Silverfox
Old Aug 31, 2019 | 11:33 AM
Cat Man HHR's Avatar
Originally Posted by Doc brown
This is why Wisconsin banned them back in the mid-70s.
They where band in a lot of states.
I use to use the tool to install the studs when you had the snow tires to accept them.
Old Aug 31, 2019 | 11:37 AM
Defrost is a problem. This is my second HHR and it's the same as the first.
Should have had it broadcast out more towards the end of the wind shield.
Like people said, a quality tire just for snow is the way to go.
Shutting off traction control helps at times also.
Old Aug 31, 2019 | 12:40 PM
Silverfox's Avatar
Later they found a way to just drill the hole and insert the stud providing you had a tire with enough solid spots to drill.
You also had to have enough tread depth left on used tires.
I never felt that was such a good idea as we had many people come back and ask why they were missing so many studs when they took them off.
SF
Old Aug 31, 2019 | 01:26 PM
  #26
wren's Avatar
The 2LT HHR is the model that came with 17's. Look at the RPO sticker in the glovebox (if that sticker is still there) then you can look at this link to decode your cars options= link- post #10 -https://www.chevyhhr.net/forums/gene...options-12674/
If your's has no sticker here's part of the RPO list that shows the wheel/ tire options.
N85 Wheel - 17 X 6.5, Aluminum
PZ4 Wheel - 18 X 7.5 Aluminum, Polished
QBV Tire All - P215/50R17-90S BW ST TL AL2
QB5 Wheel - 16 X 6.5, Steel
QDB Tire All - P215/55R16-91S BW R/PE ST TL AL2
QDJ Tire All - P215/55R16-91H BW R/PE ST TL AL3
QP2 Wheel - 17 X 6.5, Aluminum Polished
Q8H Mud Flaps - FRT and RR, Formed
SAL Plant Code - Ramos Arizpe, Mexico
TBD Tire All - P225/45R18 AL3 All Season
Thanks for the info. That's gonna be mighty handy.
Wren
Old Aug 31, 2019 | 02:50 PM
  #27
SF
Gee. Why do you think the studs were outlawed ?
Old Aug 31, 2019 | 04:28 PM
  #28
Silverfox's Avatar
Yeah ... When the studs came out it was probably mostly at higher speeds and Guess where they all went ?????????
Good By Windshield......
But mainly, they were outlawed because of the Costly Major Road Damage.
SF
Old Sep 2, 2019 | 02:02 AM
  #29
geg's Avatar
geg
Tire spikes are prohibited in many European countries.
Perhaps this makes sense where the winter is not very snowy and the roads are bare asphalt.
I myself ride on "sticky" tires (Blizzak), and in the city it is justified. But when I get on the roads in villages or small settlements - I regret that I do not have spikes. Tightly packed snow does not give even weak directional stability. And in combination with deep ruts from timber trucks and agricultural machinery, the road generally turns into a Shapito circus. Once I got on the road leading to the tank training ground - it was a nightmare in reality. Good thing I always have a shovel in the cabin.
Fortunately, I rarely travel to winter villages.
Old Sep 2, 2019 | 08:36 AM
  #30
Silverfox's Avatar
One downside to the HHR is the fact you cannot use Chains.......Not enough clearance.
There are situations where they work better then Snow tires but they have there down sides too.
SF.
