Where’s the air
Old Mar 26, 2024 | 03:27 PM
cj-five's Avatar
I have a 2006 HHR with factory aluminum wheels and I’ve been having a problem with them loosing air literally for years. Anyone else have the same problem? If so, any fixes besides changing wheels?
Old Mar 26, 2024 | 04:22 PM
I’ve fixed your duplicate posts, I have a set of 2006 2LT 17” aluminium wheels they leak around the bead area and when I get a chance , I’ll break the bead and clean the rim then re inflate the tire . I bought a tire machine from Amazon a year ago to replace TPMS sensors and it’s useful for any tire problems. There are a ton of YouTube videos about tire bead sealer and different processes to fix bead leaks
Old Mar 26, 2024 | 06:33 PM
greg8453's Avatar
If you break it down use bead sealer when finishing up.
Old Mar 26, 2024 | 07:04 PM
fastsuv's Avatar
Here's what I use:
Though I have also had success with cleaning the aluminum rim edge COMPLETELY so there is no residual black rubber on the rim. It's hard to remove sometimes.
Steve
Old Mar 26, 2024 | 08:08 PM
Might be wrong or improperly installed vale stems.
Old Mar 27, 2024 | 06:41 AM
Test with soapy water
Old Mar 27, 2024 | 01:33 PM
greg8453's Avatar
You want to find leaks using bubbles? Mix 10 parts water and 1 part simple green and spray away. Real slow small leaks like around the rim it will foam.
cj-five
Apr 28, 2022 06:35 AM
RnAm
Jun 19, 2015 05:25 PM
hhr06NJ
Sep 17, 2014 09:44 AM
HHR*Chevrolady
7
Sep 11, 2010 03:18 PM
