where can i find hhr cargo safety net for the back interior?
You can definitely get one from the dealer. The car should have come with one, however, if yours is an 07 and an LS...I don't believe they come with them then...but I could be wrong.
I did check on eBay and found one for $18.99 plus shipping...but I would definitely check with the dealer to see if you can get them to supply you with one.
You might also put a Wanted To Buy in the classified section and someone might want to part with theirs. I don't use mine...but I still would like to keep it in case I need it some time down the road.
Like jx3 said, it may be under the rear cargo shelf. That's where mine was along with the front license plate bracket, lighter and velcor strap.
