Where do I find Tire Pressure Sensors?
Old Feb 2, 2010 | 04:23 PM
esmarkey's Avatar
Originally Posted by twistrman
to do it yourself involves with a procedure of tapping your brakes etc to put it into learning mode, it blinks a blinker which tire it wants and you let the air out for like 8 seconds, and it honks at you, repeat. It is easy.
But them walking around the car with a computer for 10 seconds is easier.
Don't get me wrong, the procedure is simple, as long as you have the means to refill the tires. Since I have a compressor, it's not a problem, but I have to agree that the guy walking around my car once with his thingamabob and me sitting in the seat sure was easier
Old Feb 2, 2010 | 06:41 PM
If you are tapping on your brake pedal in order to get your 2008 into learning mode, maybe you are looking at the wrong manual?
Old Feb 2, 2010 | 08:52 PM
twistrman's Avatar
sorry about that. haven't rotated in awhile, forgot it was with they keyfob. something you tap the brakes, is it the oil life monitor?
Old Feb 3, 2010 | 12:51 PM
esmarkey's Avatar
And that one works by just pushing and holding the reset button for a few seconds
Come on Twist, your loosing it
There may be another way to reset the oil pressure monitor, but I use the reset button method... It acknowledges that it has been reset, I like that.
Old Feb 3, 2010 | 02:58 PM
twistrman's Avatar
yeah you can do one with your brakes too, for some reason mine didn't want to do it with the reset button the one time, so I did it the other way.
Old Feb 3, 2010 | 10:22 PM
  #26
87silver's Avatar
My compressor is in the barn, but I rotate my tires in my garage (separate building). I simply overinflate the tires, drive it over to the garage, then let the air out when setting each sensor. It usually ends up about 3-5lbs over, so I "zero in" at 32psi using a digital gauge.
If a gas station with an air hose is close by, this method should work as well.
StormChaser
Jul 31, 2008 07:18 AM
