Who's HHR has the most Miles
Old Oct 6, 2010 | 05:07 PM
  #41
Goose's Avatar
I'm about to turn 87k and have had it about 3 years, 4 months. My commute is 100 miles a day.....would probably have more on it but went over to the sandbox this summer so that saved on miles and have a new Road King on the way which will cut down even more miles
Seems to chew up pads and rotors a bit but other than that not many significant issues......had the front drivers side hub bearing go out right before I deployed and the passenger one went out when I came back....so I had that replaced today (both under the 100k warranty) and also the wiper transmission pooped itself...that was a 240.00 repair but really that is about it for $$ sunk into it.
One issue that has me thinking a little is that when I start it after it has been sitting overnight the is a loud...well I guess rattle and then it goes right away. Longer it sits the louder the noise is..I'm wondering if oil related as it only does it that once each day for the most part...shrug..
Old Oct 22, 2010 | 03:36 AM
  #42
FileNotFound's Avatar
Cool who's HHR has the most Miles
170221 miles as of this evening. Purchased new 3/2006
New shifter lock, New dash storage box catch, New Cat Converter (exhaust) at 88k, New entire fuse block (under hood) 88k.
Around 125k I replaced front hub drivers side, and replaced the brake pads, and changed out the zinc grill to the black chrome, added twin pin stripes along the length, removed the stock steel wheels and replaced with stock mag rims 16"
165k 3rd set of tires. Goodyear brand this time (2nd set was BF Goodrich Noisy TA's)
Front Suspension is "Shot" rattles on every slight bump.
Need to replace the entire drivers interior door liner as the door handle is broken off. It's a 384.00 part!!! for a F#@#$% door handle... and I'm up against another Cat Converter replacement IF I cannot locate someone to fix/weld an aftermarket "plug" that's leaking and causing exhaust leak into the cabin.
I sound bitter here I guess however... It's been an excellent commuter and all around vehicle. I drive the hell out of it!
Old Oct 23, 2010 | 09:31 AM
  #43
HHR CHEF 2011's Avatar
I have a 2010 HHR Gray LS Auto that just turned 3000 miles had since August 1st 2010. I do have a rattle under the drivers side dash everytime I hit a bump, like something is loose around the steering column or upper dash. What could it be?
Old Jan 18, 2011 | 02:54 PM
  #44
jbman's Avatar
09 2.2 just turned 45000 sure is nice hearing these cars are lasting, I buy nothoing but Gm cars and trucks always have never any problems with any of them except a trans went out on a 83 cavalier.
Old Jan 18, 2011 | 04:09 PM
  #45
TX-2LT's Avatar
09 with 20222 miles. I'll never catch you guys.
Old Jan 19, 2011 | 04:27 PM
  #46
geesh's Avatar
115366 miles since august 22 2009!
Old Jan 20, 2011 | 03:02 PM
  #47
LinkX's Avatar
Just turned 138000, had to run out to Bismarck ND for a repair, need to do rear brakes, struts, shocks, get new tires this spring, gonna get winter tires next fall. I just did some quick math- I have like over 50k on this set of tires, not down to the wear bars yet!
Old Jan 20, 2011 | 10:40 PM
  #48
62,832 on Paddy the '07, and 1,819 on Boo Boo the 2011.
Old Jan 21, 2011 | 12:03 AM
  #49
dozol22's Avatar
Hello all
I just got a 2007 black LS to replace my 03 Focus ZX3 with 275000 miles. Focus still runs good.
I am a courier driving about 50,000 miles a year. Mine is at 75,000.
Once the focus says bye bye I will be driving the Chevy a lot.
I am hoping to hit some high numbers in few years :)
Old Feb 13, 2011 | 09:52 PM
  #50
deliveryman's Avatar
I have 129,000 on my 09 LS that I bought new Oct. 3, 2009. Still on origional brakes and clutch.
