Wind noise/side window deflectors
Old May 28, 2012 | 10:29 PM
foolmoon_design's Avatar
To help pinpoint, run your car through a carwash, and crank up the AC. Leaks around the windows will blow bubbles, just like checking for a leaky tire.
The shape of the front windows, is not a perfect match to the door, and you should notice a little bit of bubbling where the window turns to follow the A pillar down. Hope this helps. If indeed that is where it's leaking from.
Old May 29, 2012 | 05:52 PM
Laco's Avatar
Originally Posted by Budster
ditto here! I also put a switch/fuse in position #8 so I don't have to pull it each time I tow.
Same here, on the switch, makes it much easier. If you are in Mira Loma, your are pretty close to me, in Glendora.
citation18
Oct 2, 2009 05:58 PM
NikiPowPez
31
Apr 30, 2008 06:59 PM
Lee3333
17
Jul 3, 2007 03:58 PM
Velocity12
Jun 20, 2007 07:42 AM
FXM
35
Jun 6, 2007 08:25 PM
