Zero throttle fuel usage?
Old Feb 10, 2009 | 03:00 PM
JoeR's Avatar
Originally Posted by ChevyMgr
As long as it's not Bull Poop, right?
Heh, ChevyMgr... Plenty of that here!!
That's why I use that awesome avitar!!
Old Feb 10, 2009 | 09:34 PM
c2vette's Avatar
Originally Posted by JoeR
Well, so far nobody has given the correct answer.
Most of the newer engines today have what is called DFCO (Deceleration Fuel CutOff). When certain operating parameters are met, fuel is cut to the injectors. It helps with both mileage and emissions.
When the engine approaches idle, fuel resumes to prevent stalling.
I see it all the time with my wideband O2 sensor and during tuning data logs.
Whether manual or automatic, putting it into neutral will circumvent DCFO. So, for mileage, you are better off just leaving it in gear.
Hope that helps.
EDIT... Well pitbull answered right while I was typing.
That would likely explain why with throttle closed coasting in 5th gear at 70 mph on long downhill stretches sometimes the display reads ~75 MPG and other times 99 MPG on the same road, same place. Also noticed if I declutch and re-engage it will jump up to 99 MPG.
gcsc182
2.4L Performance Tech
May 6, 2015 06:37 PM
A Crazy Canuck
Fuel Economy - Hypermiling
23
Jan 11, 2013 06:29 PM
Redshift
Dec 10, 2010 09:48 PM
HotrodHomeRecker
Dec 14, 2009 11:36 PM
